Trying to set up an SMTP email send service, but getting an exception.
Here’s my config (sanitized):
notify:
- name: "sendmail"
platform: smtp
server: "smtp.west.cox.net"
port: 587
timeout: 15
sender: "#######@cox.net"
encryption: tls
username: "######"
password: "#####"
recipient:
sender_name: "HomeAssistant"
But on loading the configuration YAML, HA chokes with this:
Error setting up platform smtp
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 93, in async_setup_platform
notify_service = await hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 100, in get_service
if mail_service.connection_is_valid():
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 162, in connection_is_valid
server = self.connect()
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 141, in connect
mail = smtplib.SMTP_SSL(
File "/usr/local/lib/python3.11/smtplib.py", line 1050, in __init__
SMTP.__init__(self, host, port, local_hostname, timeout,
File "/usr/local/lib/python3.11/smtplib.py", line 255, in __init__
(code, msg) = self.connect(host, port)
File "/usr/local/lib/python3.11/smtplib.py", line 341, in connect
self.sock = self._get_socket(host, port, self.timeout)
File "/usr/local/lib/python3.11/smtplib.py", line 1057, in _get_socket
new_socket = self.context.wrap_socket(new_socket,
File "/usr/local/lib/python3.11/ssl.py", line 517, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.11/ssl.py", line 1108, in _create
self.do_handshake()
File "/usr/local/lib/python3.11/ssl.py", line 1379, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1006)
Did I screw something up with my config?
Thanks for any suggestions/pointers!
