SMTP setup
  1. I am trying to setup SMTP email. It seems so simple but it’s not working. I literally copied the example configuration and left it without even changing one letter and put it into the configuration. I then restarted. When I go to developer and services and notification, it does not show up on the drop-down list. My original list didn’t show up on the drop-down list either. I added this to the end of the configuration.yaml I didn’t know where else to put it. I guess it doesn’t read it or something. I’m not sure what the deal is but it does not show up on the drop-down under services. What am I doing wrong? # Example configuration.yaml entry notify:
  • name: “NOTIFIER_NAME” platform: smtp sender: “YOUR_SENDER” recipient: “YOUR_RECIPIENT”
  1. [9:39 PM]
when I go to services the drop down doesnt list NOTIFIER_NAME or any thing else I already tried
chances are you likely need TLS
Heres my example using google:
notify:
  - name: email
        platform: smtp
        port: 587
        encryption: starttls
        server: smtp.gmail.com
        username: !secret email
        sender: !secret email
        password: !secret gmail_pass
        sender_name: Home Assistant
        recipient:
            - !secret email
Unless you have set up an email server on your system reachable at the default port, then you must supply values for server, port, username, and password so that Home Assistant has a way to send your message.
