Running as Docker container (2024.5.5). Notify SMTP used to work fine for me prior to upgrading from 2024.4 to 2024.5. Now I’m running into a [SSL] unknown error.
Below a simple python script that runs just fine inside the same container, so why isn’t working from Home Assistant?
My config:
notify:
- name: "mail_me"
platform: smtp
server: "mail.infomaniak.com"
port: 465
encryption: tls
sender: "MY@USER"
recipient: "MY@USER"
username: "MY@USER"
password: "MY PASSWORD"
The error:
2024-05-25T16:45:57.869395737Z 2024-05-25 18:45:57.863 INFO (MainThread) [homeassistant.components.notify] Setting up notify.smtp
2024-05-25T16:45:58.074324484Z 2024-05-25 18:45:58.023 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform smtp
2024-05-25T16:45:58.074596725Z Traceback (most recent call last):
2024-05-25T16:45:58.074720880Z File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 104, in async_setup_platform
2024-05-25T16:45:58.074845467Z notify_service = await hass.async_add_executor_job(
2024-05-25T16:45:58.074950213Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.075037329Z File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
2024-05-25T16:45:58.075150872Z result = self.fn(*self.args, **self.kwargs)
2024-05-25T16:45:58.075376424Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.075476907Z File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 103, in get_service
2024-05-25T16:45:58.075587367Z if mail_service.connection_is_valid():
2024-05-25T16:45:58.075680193Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.075764140Z File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 165, in connection_is_valid
2024-05-25T16:45:58.075868702Z server = self.connect()
2024-05-25T16:45:58.075959644Z ^^^^^^^^^^^^^^
2024-05-25T16:45:58.076040058Z File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 144, in connect
2024-05-25T16:45:58.076142721Z mail = smtplib.SMTP_SSL(
2024-05-25T16:45:58.076314197Z ^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.076455133Z File "/usr/local/lib/python3.12/smtplib.py", line 1022, in __init__
2024-05-25T16:45:58.076648251Z SMTP.__init__(self, host, port, local_hostname, timeout,
2024-05-25T16:45:58.076795348Z File "/usr/local/lib/python3.12/smtplib.py", line 255, in __init__
2024-05-25T16:45:58.076904974Z (code, msg) = self.connect(host, port)
2024-05-25T16:45:58.077004453Z ^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.077088129Z File "/usr/local/lib/python3.12/smtplib.py", line 341, in connect
2024-05-25T16:45:58.077241516Z self.sock = self._get_socket(host, port, self.timeout)
2024-05-25T16:45:58.077426886Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.077595422Z File "/usr/local/lib/python3.12/smtplib.py", line 1029, in _get_socket
2024-05-25T16:45:58.077729967Z new_socket = self.context.wrap_socket(new_socket,
2024-05-25T16:45:58.077830879Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.077915724Z File "/usr/local/lib/python3.12/ssl.py", line 455, in wrap_socket
2024-05-25T16:45:58.078017046Z return self.sslsocket_class._create(
2024-05-25T16:45:58.078113545Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-05-25T16:45:58.078254488Z File "/usr/local/lib/python3.12/ssl.py", line 1042, in _create
2024-05-25T16:45:58.078440121Z self.do_handshake()
2024-05-25T16:45:58.078558822Z File "/usr/local/lib/python3.12/ssl.py", line 1320, in do_handshake
2024-05-25T16:45:58.078663350Z self._sslobj.do_handshake()
2024-05-25T16:45:58.078824887Z ssl.SSLError: [SSL] unknown error (_ssl.c:1000)
This python script runs perfectly fine inside the same container:
import smtplib
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
usr = 'MY@USER'
msg = MIMEMultipart()
msg['From'] = usr
msg['To'] = usr
msg['Subject'] = 'simple email in python'
message = 'body'
msg.attach(MIMEText(message))
with smtplib.SMTP_SSL('mail.infomaniak.com',465) as mail_server:
mail_server.ehlo()
mail_server.login(usr, 'MY PASSWORD')
mail_server.sendmail(usr, usr, msg.as_string())
