I have mopidy, snapserver an snapclient configured and running. I can play music on mopidy locally, but when i try to connect to snapcast I cant play anything. Neither on the RPi nor ovia snat.net on PC.
The snapclient status is clean, no errors.
However in the snapclient status message I get
pi@raspberrypi:~ $ sudo systemctl status snapserver
● snapserver.service - Snapcast server
Loaded: loaded (/lib/systemd/system/snapserver.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-10-12 04:49:46 CEST; 9min ago
Docs: man:snapserver(1)
Main PID: 11466 (snapserver)
Tasks: 5 (limit: 779)
CPU: 14.718s
CGroup: /system.slice/snapserver.service
└─11466 /usr/bin/snapserver --logging.sink=system --server.datadir=/var/lib/snapserver
**Oct 12 04:50:01 raspberrypi snapserver[11466]: Error in socket shutdown: Transport endpoint is not connected
Oct 12 04:50:01 raspberrypi snapserver[11466]: Error while reading from control socket: Connection reset by peer**
Oct 12 04:50:51 raspberrypi snapserver[11466]: StreamServer::NewConnection: 192.168.178.63
Oct 12 04:50:52 raspberrypi snapserver[11466]: Hello from b8:27:eb:4f:08:8f, host: raspberrypi, v0.23.0, ClientName: Snapclient, OS: Debian GNU/Linux 11 (bu>
Oct 12 04:50:52 raspberrypi snapserver[11466]: Removing 8 inactive session(s), active sessions: 5
Oct 12 04:51:30 raspberrypi snapserver[11466]: ControlServer::NewConnection: 192.168.178.20
Oct 12 04:51:30 raspberrypi snapserver[11466]: Hello from f71b6193-ccf9-4d73-a4c4-7ff714e59274, host: Snapweb client, v0.4.0, ClientName: Snapweb, OS: Win32>
Oct 12 04:51:30 raspberrypi snapserver[11466]: Removing 1 inactive session(s), active sessions: 5
Can someone explain where this transport endpoint is supposed to connect to? and what is this control socket?
Is this maybe just a configuration issue like some IP somewhere not set correctly?
Cheers
F.
