I use HA to control my snapcast server - while I was on version 0.44 I was able to do so. However, since upgrading to 0.47 I cant access the snapcast component. I have gone ahead and reinstalled the latest build of snapcast which should be 0.11.1 - which should work but no luck.
Here is the error log I see on the webpage:
2017-06-27 23:17:37 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _SelectorSocketTransport._read_ready()
File “/usr/lib/python3.4/asyncio/events.py”, line 120, in _run
self._callback(*self._args)
File “/usr/lib/python3.4/asyncio/selector_events.py”, line 589,
in _read_ready self._protocol.data_received(data)
File “/home/homeassistant/.homeassistant/deps/snapcast/control/protocol.py”, line 40, in data_received
data = json.loads(cmd)
File “/usr/lib/python3.4/json/init.py”, line 318, in loads
return _default_decoder.decode(s)
File “/usr/lib/python3.4/json/decoder.py”, line 343, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/lib/python3.4/json/decoder.py”, line 359, in raw_decode
obj, end = self.scan_once(s, idx)
ValueError: Unterminated string starting at: line 1 column 1444 (char 1443)
File “/usr/lib/python3.4/asyncio/selector_events.py”, line 589, in _read_ready self._protocol.data_received(data)
File “/usr/lib/python3.4/json/decoder.py”, line 346, in decode
raise ValueError(errmsg(“Extra data”, s, end, len(s)))
ValueError: Extra data: line 1 column 4 - line 1 column 502 (char 3 - 501)
2017-06-27 23:17:46 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-06-27 23:17:46 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform snapcast is taking over 10 seconds.
2017-06-27 23:18:36 ERROR (MainThread) [homeassistant.components.media_player] Setup of platform snapcast is taking longer than 60 seconds. Startup will proceed without waiting any longer.
