Snapcast not showing client name
Snapcast tiles show ‘snapcast_client_‘mac_address’’, they used to show the name of the client.
Any ideas on how to change it?
You can give it a friendly_name using the customize option
Yes thanks, I’ve done that once but it’s so time consuming and frustrating especially when Home Assistant used to show the friendly name. I chop and change the system quite regularly, so am constantly having to go back in and try and sort out the names. I’ve moved over to Mopidy-Iris now, the friendly names are listed and I also use the app when possible.
Thanks for taking the time to reply though. :slight_smile:
You should be able to change the names outside HA if you want. Here is the link for more information on how to do it:
https://github.com/skalavala/Multi-Room-Audio-Centralized-Audio-for-Home/blob/master/Naming%20Clients.md
@skalavala This does not work with hass though. Look at the code here: https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/media_player/snapcast.py#L191
The snapcast component uses the ID as the name instead of using the friendly name which is also provided by the library from @happyleaves: https://github.com/happyleavesaoc/python-snapcast/blob/master/snapcast/control/client.py#L34
Is there a reason for that? Otherwise I would like to open a PR to change the behaviour.
