I’d like to use the Snapcast server Add-on via Home assistant.
I’ve installed this add-on but it won’t start and gives (only) the following error in the log of the Add-On:
s6-overlay-suexec: fatal: can only run as pid 1
I’ve got no idea how to fix this, also can’t find any info on how to setup the configuration for the HomeAssistant Add-On.
Anyone here able to help me out in getting snapcast server to work via HomeAssistant?
What type of home-assistant Installation are you running?
If you have it running on a Linux, install snapserver directly on Ubuntu or Raspbian. I also tried it with the addon but never got it running…
I´m running docker-supervised.
I’m running homeassistant OS in a Virtualbox VM, that probably aint gonna make it easy to instal it directly.
Also not my preferation as i like the idea of having it all in 1 place. Makes backing up and management a bit easier (among others).
Which addon have you installed? I wanted to test it on my install to maybe provide you some details or if I have the same issue, but I was not able to find an snapserver or snapcast addon in the official addon store.
Have you imported from a custom repository? If yes, from which? You should also maybe ask there as the dev should be able to help you with the issue
