Snapshot config folder incomplete - how to fix this with a config folder backup?
I have been struggling with homeassistant for a few days now. I’m trying to restore my system to a previous snapshot. Unfortunately the snapshot’s config folder is incomplete. Luckily I make offsite backups besides automated snapshots. So I have a complete (and working) config directory. Did some research on restoring homeassistant. From what I have read it is just a matter of drag-and-drop the config folder from the backup to the config folder of my new setup. That didn’t work. I was unable to get it to work. What are the steps to fix this? This is what i got from the log file after restarting HA from terminal.
https://pastebin.com/embed_js/2UwsYQ6J
I would recommend just extracting the snapshot, and then shutting it off and plugging the storage into your computer. Manually copy the config folder, put the storage back, and power on.
Or simply issuing the home assistant stop command (leaving the addon containers running).
Copying your entire backup config folder over to the system using samba or SSH.
Then issuing the home assistant start command.
Stop home assistant
ha core stop
Start home assistant
ha core start
Just to be clear. Should I delete all the files (including those in hidden folders) inside the config folder before copying?
Couldn’t hurt but I’d keep a copy off the system. Just in case your ‘complete’ replacement has worse issues.
Deleted my config folder before copying the backup and used the ha core stop and start command. Got all kinds of errors after restarting. Some were database related so stopped HA again. Removed home-assistant_v2.db. Restarted. That resulted in less errors. But still…not a working HA GUI. Lots of component errors this time.
File "/usr/src/homeassistant/homeassistant/components/nanoleaf/light.py", line 81, in setup_platform
    token = nanoleaf_light.request_token()
  File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 60, in request_token
    response = self._request("new", 'POST', authenticated=False).json()
  File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 202, in _request
    raise NotAuthorizingNewTokens(
pynanoleaf.pynanoleaf.NotAuthorizingNewTokens: Nanoleaf is not allowing new tokens,
                    please make sure to press and hold the on/off button
                    on your device for 5 seconds until the LED starts flashing
                    in a pattern.
2020-08-03 13:13:34 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:13:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:13:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:13:51 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:13:51 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:14:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:14:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:14:54 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:14:54 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:15:14 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:15:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:15:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:15:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:16:14 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:16:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:16:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:16:38 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:16:38 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:16:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:17:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:17:29 ERROR (MainThread) [pyhaversion] Timeout error fetching version information from Hassio,
2020-08-03 13:17:34 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:17:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:17:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:18:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:18:01 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:18:01 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:18:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:18:36 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x6d779490>, 'Connect timed out. (connect timeout=5.0)')': /bot1062578535:AAFVYY2Hilk9ZKA86oUBA8WCX_uJ1kl6dBY/getUpdates
2020-08-03 13:18:54 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:18:54 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:19:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:19:24 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:19:24 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:19:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:20:14 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:20:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:20:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:20:47 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:20:47 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:20:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:21:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:21:34 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:21:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:21:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:22:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:22:10 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:22:10 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:22:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:22:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:22:54 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:22:54 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:23:33 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:23:33 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:23:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:23:57 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6dca6a00>: Failed to establish a new connection: [Errno -3] Try again')': /bot1062578535:AAFVYY2Hilk9ZKA86oUBA8WCX_uJ1kl6dBY/getUpdates
2020-08-03 13:24:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:24:14 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:24:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:24:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:24:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:24:56 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:24:56 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:25:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:25:34 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:25:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:25:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:26:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:26:19 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:26:19 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:26:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:26:54 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:26:54 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:27:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:27:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:27:43 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:27:43 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:28:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:28:14 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:28:14 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:28:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:29:00 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:29:06 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:29:06 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
2020-08-03 13:29:34 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-08-03 13:29:34 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
2020-08-03 13:29:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:30:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2020-08-03 13:30:29 ERROR (MainThread) [homeassistant.components.ipp] Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
2020-08-03 13:30:29 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 80 seconds
