Snapshot Download Size Limit?
Is there a limit to the size of HAAS Snapshots? Mine is now about 400MB.
When I try to download the snapshot to my PC via the normal download feature (click the snapshot and then select download) it will download about 250MB of it and then the download fails.
If I use SAMBA to use the Windows file explorer to copy the file to my hard drive it all comes over and works fine…
Anyone else have this issue?
I have the same problem. This started after installing the zigbee2mqtt add-on.
Sounds like you need to adjust your recorder settings.
How do you do that? I can see no way to adjust or even see the “Recorder Settings”
The snapshot works… the download fails… and it fails at the same spot… about 250M
There is a known issue with Firefox that would cause that, it just breaks the connection while downloading
make sure you download using local ip instead of Domain.
Ya that was it… Works fine in Chrome. Fails in FireFox… I guess it is time to dump this “once was”/ “never will be” browser…
