Snapshot is only restoring add-ons
I took a protected snap shot, wiped my SD card, and attempted to restore my snap shot. Logs show it is completed but the only thing restored are the add-ons. I have restarted the the Pi, retried the whole process again but can’t get a restore going. I can’t access the restore with 7-zip because (I assume) it’s protected.
What else can I do to get this restored?
18-11-25 02:29:14 INFO (MainThread) [hassio.snapshots] Full-Restore d5ac4dec start
18-11-25 02:29:14 INFO (MainThread) [hassio.addons] Shutdown application stop 0 add-ons
18-11-25 02:29:14 INFO (SyncWorker_2) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-11-25 02:29:47 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-11-25 02:29:47 INFO (MainThread) [hassio.addons] Shutdown services stop 3 add-ons
18-11-25 02:29:47 INFO (SyncWorker_5) [hassio.docker.interface] Stop homeassistant/armhf-addon-ssh Docker application
18-11-25 02:29:47 INFO (SyncWorker_4) [hassio.docker.interface] Stop danimtb/armhf-dasshio Docker application
18-11-25 02:29:47 INFO (SyncWorker_11) [hassio.docker.interface] Stop homeassistant/armhf-addon-samba Docker application
18-11-25 02:29:50 INFO (SyncWorker_4) [hassio.docker.interface] Clean danimtb/armhf-dasshio Docker application
18-11-25 02:29:50 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/armhf-addon-ssh Docker application
18-11-25 02:29:59 INFO (SyncWorker_11) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba Docker application
18-11-25 02:29:59 INFO (MainThread) [hassio.addons] Shutdown system stop 0 add-ons
18-11-25 02:29:59 INFO (MainThread) [hassio.addons] Shutdown initialize stop 0 add-ons
18-11-25 02:29:59 INFO (MainThread) [hassio.snapshots] Restore d5ac4dec run folders
18-11-25 02:29:59 INFO (SyncWorker_9) [hassio.snapshots.snapshot] Restore folder addons/local
18-11-25 02:29:59 INFO (SyncWorker_4) [hassio.snapshots.snapshot] Restore folder share
18-11-25 02:29:59 INFO (SyncWorker_5) [hassio.snapshots.snapshot] Restore folder ssl
18-11-25 02:29:59 INFO (SyncWorker_4) [hassio.snapshots.snapshot] Restore folder share done
18-11-25 02:29:59 INFO (SyncWorker_9) [hassio.snapshots.snapshot] Restore folder addons/local done
18-11-25 02:29:59 INFO (SyncWorker_5) [hassio.snapshots.snapshot] Restore folder ssl done
18-11-25 02:29:59 INFO (MainThread) [hassio.snapshots] Restore d5ac4dec run Home-Assistant
18-11-25 02:29:59 INFO (MainThread) [hassio.snapshots] Restore d5ac4dec run Repositories
18-11-25 02:29:59 INFO (MainThread) [hassio.addons] Load add-ons: 47 all - 0 new - 0 remove
18-11-25 02:29:59 INFO (MainThread) [hassio.snapshots] Restore d5ac4dec old add-ons
18-11-25 02:29:59 INFO (MainThread) [hassio.addons.addon] Restore config for addon core_samba
18-11-25 02:29:59 WARNING (MainThread) [hassio.homeassistant] Version 0.82.1 is already installed
18-11-25 02:29:59 INFO (MainThread) [hassio.addons.addon] Restore config for addon 03d23610_dasshio
18-11-25 02:29:59 INFO (MainThread) [hassio.addons.addon] Restore data for addon core_samba
18-11-25 02:29:59 INFO (MainThread) [hassio.addons.addon] Restore data for addon 03d23610_dasshio
18-11-25 02:30:00 INFO (MainThread) [hassio.addons.addon] Restore config for addon core_ssh
18-11-25 02:30:00 INFO (MainThread) [hassio.addons.addon] Restore data for addon core_ssh
18-11-25 02:30:00 INFO (MainThread) [hassio.addons.addon] Restore config for addon core_letsencrypt
18-11-25 02:30:00 INFO (MainThread) [hassio.addons.addon] Restore image for addon core_letsencrypt
18-11-25 02:30:00 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/armhf-addon-letsencrypt tag 2.2.
18-11-25 02:30:05 INFO (SyncWorker_14) [hassio.docker.addon] Start Docker add-on danimtb/armhf-dasshio with version 0.3.1
18-11-25 02:30:05 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-samba with version 3.0
18-11-25 02:30:07 INFO (SyncWorker_11) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-ssh with version 3.5
18-11-25 02:30:33 INFO (SyncWorker_9) [hassio.docker.interface] Tag image homeassistant/armhf-addon-letsencrypt with version 2.2 as latest
18-11-25 02:30:33 INFO (MainThread) [hassio.addons.addon] Restore data for addon core_letsencrypt
18-11-25 02:30:33 INFO (MainThread) [hassio.addons.addon] Finish restore for add-on core_letsencrypt
18-11-25 02:30:33 INFO (MainThread) [hassio.snapshots] Restore d5ac4dec wait until homeassistant ready
18-11-25 02:30:51 INFO (SyncWorker_13) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.82.1
18-11-25 02:31:21 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-11-25 02:31:21 INFO (MainThread) [hassio.snapshots] Full-Restore d5ac4dec done
What is protected? Are you saying the snapshot can’t be opened in 7zip? It’s not protected unless you created it with a password.
It looks like it’s restored everything to me… what is missing?
I protected it with a password.
And the logs show everything is restored but in reality none of my yamls came over.
tempted to ask why you would do that… but anyway moving along… You should be able to open it in 7zip and the largest archive in there will be the home assistant one… check through that and you might find your yaml files in there. Have you tried looking with samba to see what is in your config folder?
Just the default .yamls in the config folder.
7zip is unable to open the biggest archive with this error:
well that explains it - it’s incomplete/corrupt by the look of it
Lesson learned - test backup before wiping.
Luckily I had everything but secrets.yaml in my GitHub and have rebuilt from there.
Well that’s a plus…
I use github desktop and I sync my config folder with the github folder on my PC and that contains my secrets file but that isn’t sync’ed when I push to master so I always have a backup. I use WinSCP to sync the /config with the github desktop folder…
