Snapshot restore from CLI
Hello guys. Just installed Hass.IO, which was a really great experience.
Well, until I tried installing: MariaDB, DuckDNS, Update notifier, SAMBA and SSH.
After rebooting the Pi3, I was not able to access the frontend.
I could SSH in, and got a very large error log.
But I guess that’s what happens. Doing a reinstall now.
What I really would like to propose, is a feature request for Hass.IO, which is being able to restore a snapshot from CLI.
This will help out a lot of people if they lost access to the frontend.
What do you guys think? Would this be a good idea?
The Hass.io API has actually support for it…
Will look into adding it to the hassio cli.
That sound great. Thanks!
On this topic, is there documentation somewhere about:
  1. How to do a snapshot restore?
  2. How to delete old/unused snapshots?
eric24
Did you determine how to delete stale snapshots?
I would like to know how to delete a snapshot. Anyone?
Can you not just delete the backup file the snapshot creates (and probably then re-start home assistant)?
Deleting the backup file from the file system seems to work. It didn’t require a restart, just a refresh of the page to see the update.
Did you learn how to restore a snapshot from command line?
I can’t access a remote HassIO (that is in my mothers appartment), and I want to restore a snapshot with SSH.
has there been any update on this? I was not able to access my instance of home assistance with anything but SSH and this would have helped
No sorry. Still haven’t figured it out.
core-ssh:~# hassio sn list
“result”: “ok”,
“data”: {
“snapshots”: [
“slug”: “fdbd0cc3”,
“name”: “l\u00f6rdag 31 mars 2018”,
“date”: “2018-03-31T09:49:27.172052+00:00”,
“type”: “full”,
“protected”: false
“slug”: “7d4a8170”,
“name”: “torsdag 5 apr. 2018”,
“date”: “2018-04-05T10:44:31.096484+00:00”,
“type”: “full”,
“protected”: false
core-ssh:~# hassio sn restore -name fdbd0cc3
The CLI above, should actually read;
core-ssh:~# hassio sn restore -slug your_snapshot_slug_name
Your answers were very helpful. Only problem is when I issue the hassio sn list command, I get the following
“result”: “ok”,
“data”: {
“snapshots”: []
indicating that there are no snapshots.
The name of the file created by the create snapshot is
Hass_io_Wednesday_Aug_22_2018.tar and length is 2370 KB
I put it in a folder called backup and also in the folder with the yaml files and stuff.
What am I missing?
you need to do a:
hassio sn reload
to refresh the list of snapshots
Thanks, but that did not help…same results
If you don’t mind one more inquiry.
I used “hassio sn new” to create a new snapshot. It worked fine and even shows up in available snapshots .
But I cant see it anywhere on the sd card using samba. If I could find it I could put the one that I want to restore in the same place.
in samba (I’m assuming you installed the samba addon) there will be a folder called backup
The snapshots live in the backup folder.
Make sure the options look something like this:
  "workgroup": "WORKGROUP",
  "name": "debian",
  "guest": false,
  "map": {
    "config": true,
    "addons": true,
    "ssl": true,
    "share": true,
    "backup": true
  "username": "username",
  "password": "password",
  "interface": "",
  "allow_hosts": [
    "x.x.x.0/24",
    "172.16.0.0/12"
Thanks for your help. I did not see what you saw. So I messed around a lot and finally figured it out.it.
I only saw config(\HASSIO) ( Z:)
I now also see backup(\hassio) (Y:) and it contains the snapshot that I created.
So all I should have to do is move the other one into this place and go.
Huge learning curve. Thanks again
Tom
Just remember when you copy over a snapshot you need to refresh in the snapshots tab or
hassio sn reload
from ssh.
