I am currently trying to recover from a sd-card failure but am having some issues with restoring the snapshot.
What I am doing:
Clean flash of a new image
Initialise home assistant and add samba support
Upload my snapshot (i use google drive backup)
Restore the snapshot (from the web interface or command line)
It seems to recover all add-ons however non of the home assistant configs are being recovered.
I found some other references to similar behaviour but not a real solution.
I also tried recovering using the command-line using a physical keyboard etc but not much more luck.
Any pointers on where I can start looking on what is going wrong?
It was doing full backups at least that is how I configured it. Looking in the backup it does contain the home assistant archive with the configs. But they do not seem to be recovered.
I did notice that the node red flows where not in the archive.
I was however able to recover them from the old Micro-SD card (which is still readable but not writable)
Any idea where some stuff like the users etc are located?
