The snapshot runs locally on your home assistant server. It has nothing to do with Nabu Casa.
That’s way too drastic. No need for a reinstall at all.
Just a little update.
If I exclude the share and media folder the snapshot is fine.
Thats ok for me, i dont need the share an media folder in my backup
regards Tim
I am having this issue also. I can not make or restore a snapshot. Error on attempting to restore is ‘‘Error: Unknown error, see supervisor’’. Log records ‘HomeAssistantCore.update’ blocked from execution, system is not healthy" when I attempt to upgrade to latest H/A Supervisor version 0.118.2 from 0.118.0.Any suggestions?
Yes, same problem here. I noticed over the last few days since updating to version 0.118.0, that I cannot update the core. As well my daily snapshots have not happened for the same time period.
I see:
Update Available
Home Assistant Core 0.118.3
You are currently running version 0.118.0
When I select I get the next box:
Update Home Assistant Core
Are you sure you want to update Home Assistant Core to version 0.118.3?
and when I select that button, nothing happens.
When I look in the log I see:
WARNING (MainThread) [supervisor.jobs] ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
WARNING (MainThread) [supervisor.jobs] ‘SnapshotManager.do_snapshot_full’ blocked from execution, system is not healthy
I also tried to install an Add-On, and then I see:
WARNING (MainThread) [supervisor.jobs] ‘AddonManager.install’ blocked from execution, system is not healthy
Host System is an Intel Nuc
Operating System Ubuntu 20.04.1 LTS
Docker version 19.03.13
Running Nabu Casa
Supervisor
Version 2020.11.2
Newest Version 2020.11.0
Channel stable
You are running an unsupported installation.
I’ve done multiple restarts of HA, full reboots of host system, and tried through VNC and the iOS apps. No joy.
Is it possible that the update to 0.118.0 caused an error?
I recognize Supervisor is not supported for Ubuntu 20.04.1 LTS. Is it even possible to not run Supervisor, and should I remove it somehow? How does one figure out why the “system is not healthy”? The “More Info” link just takes me to the log where I see the above entries.
Is there a way to run updates manually?
Thanks!
there’s an open ISSUE
Should be fixed with latest Supervisor 2020.11.3
so for all of us having this exact same problem, how do we get Supervisor 2020.11.3 if we’re running Docker/Portainer?
I tried joining the beta channel, surprised to see 1.0!! but cannot update:
20-12-03 01:30:45 WARNING (MainThread) [supervisor.jobs] ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
Docker version
19.03.13
2020.12.2
20-12-03 01:28:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-03 01:28:56 INFO (MainThread) [__main__] Running Supervisor
20-12-03 01:28:56 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
20-12-03 01:28:56 CRITICAL (MainThread) [supervisor.core] System running in a unhealthy state and need manual intervention!
20-12-03 01:28:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-12-03 01:28:56 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-12-03 01:28:56 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-12-03 01:28:56 CRITICAL (MainThread) [supervisor.misc.hwmon] Not privileged to run udev monitor!
20-12-03 01:28:56 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-12-03 01:28:56 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-03 01:28:56 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
20-12-03 01:28:56 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
20-12-03 01:28:56 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-03 01:28:56 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-03 01:28:58 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-03 01:29:23 INFO (MainThread) [supervisor.snapshots] Found 10 snapshot files
20-12-03 01:30:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-12-03 01:30:27 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
20-12-03 01:30:45 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
Same problem for me. Unable to update any addons as well.
Anyone? How do you install a previous version of supervisor on Docker??
Wow. No answers on this forum. 'com guys. This is a BIG deal and it’s affecting a LOT of people.
Here is the solution. I’ve outlined the very specific steps to fix this problem on Supervised Linux installs. It may work on other installs. I don’t know:
somebody mark this as th solution pls.
Hello. I’m a newbie here …
When installing HA for the first time, I also encounter this error …
I would like you to help me, as I don’t know how I find my Home assistant install directory.
I have a virtual machine with Ubuntu Server running, so how do I do the steps mentioned?
Thanks a lot!
I’m running 2021.2.3 and I have the same error:
‘SnapshotManager.do_snapshot_full’ blocked from execution, system is not running - CoreState.FREEZE
I’m getting this error now. I’m on core-2021.3.0, supervisor-2021.03.4.
I saw the Core update to core-2021.3.1 is available, and tried to make a snapshot before updating. This was the result:
Tried it twice, same error. This is in the Core logs:
2021-03-05 08:15:54 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /snapshots/new/full request
2021-03-05 08:15:54 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /snapshots/new/full -
2021-03-05 08:38:56 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /snapshots/new/full request
2021-03-05 08:38:56 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /snapshots/new/full -
How can I fix this? Thanks.
Having the same issue here.
Running on Debian 10 unable to update supervisor manually either.
Have rebooted super visor manually and tried to update manually issue persits
Same issue here using a pi4! I cant update to the new version and cant restore an snapshot. event not with command line. seems the last release broke it all.
This morning, I noticed that the Update message was saying that core-2021.3.2 was available (yesterday it was core-2021.3.1), so I tried taking a snapshot again. Note: I did not restart either the Core or the Supervisor.
This time it succeeded without reporting “unknown errors”. I was then able to upgrade to core-2021.3.2 without problems.
Curiouser and curiouser…
Yes, I’ve restarted Home Assistant this morning and I was finally able to upgrade to the latest version.
geting this same error. looks to be the zha integration. i used to have this integration but dont use it anymore so deleted it but there looks to be some left overs thats causing errors. any way to fix this?
537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36)
2023-02-09T17:34:25.927837530Z Traceback (most recent call last):
2023-02-09T17:34:25.927842095Z File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
2023-02-09T17:34:25.927845474Z await func(hass, connection, msg)
2023-02-09T17:34:25.927848590Z File "/usr/src/homeassistant/homeassistant/components/backup/websocket.py", line 70, in handle_create
2023-02-09T17:34:25.927858465Z backup = await manager.generate_backup()
2023-02-09T17:34:25.927861316Z File "/usr/src/homeassistant/homeassistant/components/backup/manager.py", line 172, in generate_backup
2023-02-09T17:34:25.927864192Z raise result
2023-02-09T17:34:25.927866736Z File "/usr/src/homeassistant/homeassistant/components/zha/backup.py", line 16, in async_pre_backup
2023-02-09T17:34:25.927869449Z zha_gateway: ZHAGateway = hass.data[DATA_ZHA][DATA_ZHA_GATEWAY]
2023-02-09T17:34:25.927872049Z KeyError: 'zha_gateway'
Hi, I’m experiencing the same issue.
A reboot didn’t help. Interestingly, only the full backup didn’t work. The .tar file from the log doesn’t exist:
➜ /data cd /data/backup
cd: no such file or directory: /data/backup
23-12-05 08:19:46 INFO (MainThread) [supervisor.api.middleware.security] /dns/info access from a0d7b954_nginxproxymanager
23-12-05 08:19:49 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-05 08:19:49 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-05 08:19:50 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-05 08:19:50 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-12-05 08:49:29 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-05 09:16:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-12-05 09:16:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-05 09:16:51 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-12-05 09:16:51 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-12-05 09:19:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-05 09:49:31 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-05 10:03:54 INFO (MainThread) [supervisor.backups.manager] Found 315 backup files
23-12-05 10:03:55 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/80379ab8.tar: unexpected end of data
23-12-05 10:03:55 INFO (MainThread) [supervisor.backups.manager] Found 315 backup files
23-12-05 10:03:56 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/80379ab8.tar: unexpected end of data
23-12-05 10:04:02 INFO (MainThread) [supervisor.backups.manager] Backup fc81b49a starting stage addon_repositories
23-12-05 10:04:02 INFO (MainThread) [supervisor.backups.manager] Backup fc81b49a starting stage docker_config
23-12-05 10:04:02 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug fc81b49a
23-12-05 10:04:02 INFO (MainThread) [supervisor.backups.manager] Backup fc81b49a starting stage addons
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_grafana
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_grafana
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_wireguard
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_wireguard
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 5c53de3b_esphome
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 5c53de3b_esphome
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_configurator
23-12-05 10:04:02 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_configurator
23-12-05 10:04:03 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mariadb
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mariadb
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_ssh
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_ssh
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_logviewer
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_logviewer
23-12-05 10:04:26 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_influxdb
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_influxdb
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_duckdns
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_duckdns
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mosquitto
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mosquitto
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 7d06b5a0_argon_one_temp
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 7d06b5a0_argon_one_temp
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_sonweb
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_sonweb
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 45df7312_zigbee2mqtt
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 45df7312_zigbee2mqtt
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_jupyterlablite
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_jupyterlablite
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_sponsorblockcast
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_sponsorblockcast
23-12-05 10:04:32 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_teamspeak
23-12-05 10:04:41 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_teamspeak
23-12-05 10:04:41 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_motioneye
23-12-05 10:04:41 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_motioneye
23-12-05 10:04:41 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_nextcloud_ocr
23-12-05 10:09:16 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_nextcloud_ocr
23-12-05 10:09:16 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_vscode
23-12-05 10:09:22 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_vscode
23-12-05 10:09:22 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_bitwarden
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_bitwarden
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_nginxproxymanager
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_nginxproxymanager
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_calibre
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_calibre
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_calibre-web
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_calibre-web
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_tandoor_recipes
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_tandoor_recipes
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on db21ed7f_guacamole
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon db21ed7f_guacamole
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_uptime-kuma
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_uptime-kuma
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a889bffc_go2rtc
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a889bffc_go2rtc
23-12-05 10:09:24 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on b9f12d83_psacc
23-12-05 10:09:50 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon b9f12d83_psacc
23-12-05 10:09:50 INFO (MainThread) [supervisor.backups.manager] Backup fc81b49a starting stage home_assistant
23-12-05 10:09:50 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
23-12-05 10:19:33 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-05 10:20:20 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
23-12-05 10:20:20 INFO (MainThread) [supervisor.backups.manager] Backup fc81b49a starting stage folders
23-12-05 10:20:20 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder share
23-12-05 10:20:21 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder share done
23-12-05 10:20:21 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder addons/local
23-12-05 10:20:21 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder addons/local done
23-12-05 10:20:21 INFO (SyncWorker_1) [supervisor.backups.backup] Backing up folder ssl
23-12-05 10:20:21 INFO (SyncWorker_1) [supervisor.backups.backup] Backup folder ssl done
23-12-05 10:20:21 INFO (SyncWorker_6) [supervisor.backups.backup] Backing up folder media
I noticed the following line:
I had some .tar files in the backup folder that would not show up in GUI. went in with terminal app and deleted them. now I am able to do backups again.
