Every time I try to snapshot I get the same error:
18-05-27 16:06:10 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<Snapshot.store_addons…_addon_save() done, defined at /usr/lib/python3.6/site-packages/hassio/snapshots/snapshot.py:254> exception=ReadTimeout(ReadTimeoutError(“UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=300)”,),)>
I’ve tried restoring this backup on a different SD card and at least mqtt comes up with errors. Aswell as another add-on which I can’t recall at the moment.
Traceback
18-05-27 16:01:10 INFO (MainThread) [hassio.snapshots] Full-Snapshot 63fcbd50 start
18-05-27 16:01:10 INFO (MainThread) [hassio.snapshots] Snapshot 63fcbd50 store Add-ons
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_mosquitto
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_ssh
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_configurator
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_duckdns
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_mosquitto
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_mariadb
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Build snapshot for addon core_samba
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_configurator
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_samba
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_ssh
18-05-27 16:01:10 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_duckdns
18-05-27 16:01:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-05-27 16:01:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-05-27 16:01:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-05-27 16:03:06 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_mariadb
future: <Task finished coro=<Snapshot.store_addons.._addon_save() done, defined at /usr/lib/python3.6/site-packages/hassio/snapshots/snapshot.py:254> exception=ReadTimeout(ReadTimeoutError(“UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=300)”,),)>
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 387, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 383, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.6/http/client.py”, line 1331, in getresponse
response.begin()
File “/usr/lib/python3.6/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.6/http/client.py”, line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/lib/python3.6/socket.py”, line 586, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3.6/site-packages/urllib3/util/retry.py”, line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3.6/site-packages/urllib3/packages/six.py”, line 686, in reraise
raise value
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 389, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 309, in _raise_timeout
raise ReadTimeoutError(self, url, “Read timed out. (read timeout=%s)” % timeout_value)
urllib3.exceptions.ReadTimeoutError: UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=300)
File “/usr/lib/python3.6/site-packages/hassio/snapshots/snapshot.py”, line 261, in _addon_save
if not await addon.snapshot(addon_file):
File “/usr/lib/python3.6/site-packages/hassio/addons/utils.py”, line 33, in wrap_check
return await method(addon, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/hassio/addons/addon.py”, line 741, in snapshot
self.instance.export_image(Path(temp, “image.tar”)):
File “/usr/lib/python3.6/site-packages/hassio/utils/init.py”, line 25, in wrap_api
return await method(api, *args, **kwargs)
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/hassio/docker/addon.py”, line 313, in _export_image
image = self.sys_docker.api.get_image(self.image)
File “/usr/lib/python3.6/site-packages/docker/utils/decorators.py”, line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/docker/api/image.py”, line 40, in get_image
res = self._get(self._url(“/images/{0}/get”, image), stream=True)
File “/usr/lib/python3.6/site-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/lib/python3.6/site-packages/docker/api/client.py”, line 194, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 521, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 521, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=300)
18-05-27 16:06:15 INFO (MainThread) [hassio.snapshots] Snapshot 63fcbd50 store folders
18-05-27 16:06:15 INFO (SyncWorker_0) [hassio.snapshots.snapshot] Snapshot folder ssl
18-05-27 16:06:16 INFO (SyncWorker_18) [hassio.snapshots.snapshot] Snapshot folder homeassistant
18-05-27 16:06:16 INFO (SyncWorker_19) [hassio.snapshots.snapshot] Snapshot folder share
18-05-27 16:06:16 INFO (SyncWorker_13) [hassio.snapshots.snapshot] Snapshot folder addons/local
18-05-27 16:06:16 INFO (SyncWorker_13) [hassio.snapshots.snapshot] Snapshot folder addons/local done
18-05-27 16:06:16 INFO (SyncWorker_0) [hassio.snapshots.snapshot] Snapshot folder ssl done
18-05-27 16:06:17 INFO (SyncWorker_18) [hassio.snapshots.snapshot] Snapshot folder homeassistant done
18-05-27 16:11:18 INFO (SyncWorker_19) [hassio.snapshots.snapshot] Snapshot folder share done
18-05-27 16:11:25 INFO (MainThread) [hassio.snapshots] Full-Snapshot 63fcbd50 done
