Snapshotting brightness of a light
I need some help debugging a specific hiccup I have with one light used in a scene. Basically, I have automation set up that if the garage door is opened and the kitchen light is below a certain value, then raise the brightness to a specific value for 5 minutes, then go back to the prior brightness.
This automation also turns on the garage lights and others, which work perfectly as they are simple on/off switches for the lights. When I trigger the automation, I create a scene and snapshot the entities. This seemingly works, then I raise the brightness, and when the time comes, I activate the scene.
Now here’s the rub, this particular light supports color warmth and RGB. When I create a scene on it and then activate the scene, it is changing the light from a warm white to a purple. I figure the device is being particular to some of the attributes being saved in the scene. I am trying to figure out a way to tweak the scene or store the value in a script variable for use later. Anyone have thoughts on how to handle a scenario light this?
Here is my automation:
alias: Brighten Kitchen when Garage Door opens
description: ""
triggers:
  - type: opened
    device_id: fcab010312600d5ef286c0491392698f
    entity_id: d1ea386c68ef8000748bf5300adc720a
    domain: binary_sensor
    trigger: device
  - type: motion
    device_id: b01c7645c036b625f4f60839735a24d4
    entity_id: c3a3f186ac2da0b6431e58fc247c8aba
    trigger: device
  - type: motion
    device_id: 09c8a7623f5b9e199d38d4b950d9efe4
    entity_id: ff053c3237531804e02332958f8763b8
    trigger: device
conditions:
  - condition: and
    conditions:
      - condition: device
        type: is_off
        device_id: 66481397c5fcb262ccfe086b3286618e
        entity_id: 16689c96c4685a43c9605f37bb8212d3
        domain: light
      - condition: device
        type: is_off
        entity_id: 0291a42c1da93499748e144410093eda
        domain: switch
      - condition: device
        type: is_on
        device_id: f6a52b0935a6e7cb02ac1f337d5aa030
        entity_id: 6a152c0d457d4bcc40a47e1c49075f49
        domain: light
      - condition: or
        conditions:
          - condition: sun
            after: sunset
            after_offset: "-01:30"
          - condition: sun
            before: sunrise
            before_offset: "00:45"
actions:
  - data:
      scene_id: garage_door_open_revert
      snapshot_entities:
        - light.kitchen_sink_light
        - light.kitchen_garage_smart_relay_l1
        - light.kitchen_garage_smart_relay_l2
    action: scene.create
  - if:
      - condition: numeric_state
        entity_id: light.kitchen_sink_light
        below: 127
        attribute: brightness
    then:
      - target:
          entity_id:
          brightness_pct: 50
        action: light.turn_on
  - data: {}
      entity_id:
  - delay:
      hours: 0
      minutes: 5
      seconds: 0
      milliseconds: 0
  - data:
      entity_id: scene.garage_door_open_revert
    action: scene.turn_on
  - target:
      entity_id:
        - scene.garage_door_open_revert
      device_id: []
      area_id: []
    data: {}
    action: scene.delete
mode: single
In case it helps, this is the States view of the light when at 30%
min_color_temp_kelvin: 2702
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 370
supported_color_modes:
  - color_temp
  - hs
color_mode: hs
brightness: 76.5
color_temp_kelvin: null
color_temp: null
hs_color:
  - 28
  - 56
rgb_color:
  - 255
  - 179
  - 112
xy_color:
  - 0.492
  - 0.384
friendly_name: Kitchen Sink Light
supported_features: 0
In case anyone ever comes across this thread, I want to share that I never found how to address the core concern, but managed a workaround. I pulled the problematic light out of the scene and instead define a temporary variable in the automation and then use that variable to set the brightness later.
Save initial brightness level:
  - variables:
      kitchen_sink_light_old_brightness: >-
        {{ state_attr('light.kitchen_sink_light', 'brightness') | default('64')
When restoring the prior brightness:
  - action: light.turn_on
    metadata: {}
      brightness: "{{ kitchen_sink_light_old_brightness | int }}"
    enabled: true
      entity_id:
    alias: Restore prior Kitchen Sink Light Brightness
I just came across this thread.
I am not sure what was going on with the scene-based approach, but if all you care about is the brightness of the light, I was going to suggest a similar approach.
Doing it in a variable as you are is just fine. Another option, especially if you need to access the light’s brightness in a separately triggered automation, is to store it in an input_number helper.
