HI,
I’ve just started with Snips, so i’m quite new, but have the feeling that i’m starting to understand things…
I’ve noticed that making your own app, with correct slots helps a lot with getting it to recognize my broken speech. However, i find that it sometimes doesn’t match exactly and in those cases home assistant just throws an exception, instead of saying something or, better, making a better guess.
A simple example:
2019-08-19 21:33:58 ERROR (MainThread) [homeassistant.components.snips] Error while handling intent: HassLightSet.
File "/data/home/homeass/homeassistant/lib/python3.6/site-packages/homeassistant/components/snips/__init__.py", line 137, in message_received
hass, DOMAIN, intent_type, slots, request['input'])
File "/data/home/homeass/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/intent.py", line 64, in async_handle
result = await handler.async_handle(intent)
File "/data/home/homeass/homeassistant/lib/python3.6/site-packages/homeassistant/components/light/__init__.py", line 199, in async_handle
[state for state in hass.states.async_all()
File "/data/home/homeass/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/intent.py", line 110, in async_match_state
'Unable to find an entity called {}'.format(name))
homeassistant.helpers.intent.IntentHandleError: Unable to find an entity called living room lights
How can this be improved? Can i override the standard intents?
I have also noticed that there’s some apps inside snips that use ‘up’ and ‘down’ for the light-set option, i believe that needs a script to then push brightness up/down for lights. Does anybody have a good script for that?
