receive also errors in LOG
pi@raspberrypi:~ $ docker run -t --rm --name snips --log-driver none -v /home/pi /.asoundrc:/root/.asoundrc -v /opt/snips/config:/opt/snips/config --privileged - v /dev/snd:/dev/snd snipsdocker/platform --mqtt 192.168.1.25:1883
google-asr is disabled
Spawning /usr/bin/snips-asr /usr/share/snips/asr --acoustic_scale=0.83 --endpoin ting=false,4.0,inf,0.0:true,0.5,2.0,0.0:true,1.0,8.0,0.0:true,2.0,inf,0.0:false, 0.0,inf,10.0 --beam_size=8 mqtt
Spawning /usr/bin/snips-audio-server mqtt --frame=256
Spawning /root/go/bin/tts --cs=/root/resources
Spawning /usr/bin/snips-hotword /usr/share/snips/hotword/ mqtt --threshold 0.25 --wait 40
Spawning /usr/bin/snips-queries -c /root/resources/snips.ini -p /opt/snips/confi g
Spawning /usr/bin/snips-dialogue mqtt --assistant /opt/snips/config/assistant/as sistant.json --config /usr/share/snips/dialogue --timeout 20
Spawning /usr/bin/snips-analytics -c /root/resources/snips.ini -p /opt/snips/con fig
snips-debug is disabled
2017-07-15 13:09:28,885 CRIT Supervisor running as root (no user in config file)
2017-07-15 13:09:28,901 INFO supervisord started with pid 38
2017-07-15 13:09:29,910 INFO spawned: ‘snips-tts’ with pid 41
2017-07-15 13:09:29,921 INFO spawned: ‘snips-dialogue’ with pid 42
2017-07-15 13:09:29,934 INFO spawned: ‘snips-asr’ with pid 43
2017-07-15 13:09:29,944 INFO spawned: ‘snips-analytics’ with pid 44
2017-07-15 13:09:29,955 INFO spawned: ‘snips-hotword’ with pid 45
2017-07-15 13:09:29,965 INFO spawned: ‘snips-audio-server’ with pid 46
2017-07-15 13:09:29,972 INFO spawned: ‘snips-queries’ with pid 47
2017/07/15 13:09:30 user ini.Load: open /opt/snips/config/user.ini: no such file or directory
2017/07/15 13:09:30 Mic settings file not detected, setting default sensitivity 0.5 & gain 1
2017/07/15 13:09:30 Connection to broker tcp://192.168.1.25:1883 succeded
[13:09:31.074364] INFO :snips_dialogue: Loading the configuration file
2017-07-15 13:09:31,075 INFO success: snips-tts entered RUNNING state, process h as stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,076 INFO success: snips-dialogue entered RUNNING state, proc ess has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,076 INFO success: snips-asr entered RUNNING state, process h as stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,076 INFO success: snips-analytics entered RUNNING state, pro cess has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,077 INFO success: snips-hotword entered RUNNING state, proce ss has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,077 INFO success: snips-audio-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:31,077 INFO success: snips-queries entered RUNNING state, proce ss has stayed up for > than 1 seconds (startsecs)
[13:09:31.217482] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
[13:09:31.217822] INFO :snips_analytics: Will connect to 192.168.1.25:1883
2017-07-15 13:09:31,264 INFO exited: snips-dialogue (exit status 1; not expected )
[13:09:31.302953] INFO :rumqtt::connection: $$$ Connected to broker
2017-07-15 13:09:31,308 INFO spawned: ‘snips-dialogue’ with pid 56
[13:09:31.333678] INFO :snips_dialogue: Loading the configuration file
[13:09:31.318493] INFO :rumqtt::connection: $$$ Connected to broker
[13:09:31.386150] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:31,389 INFO exited: snips-dialogue (exit status 1; not expected )
[13:09:31.488664] INFO :snips_analytics : Idle
[13:09:32.243824] INFO :reqwest::client: Request: Put https://atomic.snips.ai/v1 /billing
2017-07-15 13:09:33,252 INFO spawned: ‘snips-dialogue’ with pid 60
[13:09:33.534590] INFO :snips_dialogue: Loading the configuration file
[13:09:33.584253] ERROR:snips_hotword: HotwordError(AudioClient(AudioClientError (Io(Error { repr: Os { code: 99, message: “Cannot assign requested address” } }) , State { next_error: None })), State { next_error: None })
[13:09:33.591445] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:33,593 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:33,615 INFO exited: snips-hotword (exit status 1; not expected)
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
2017-07-15 13:09:33,646 INFO spawned: ‘snips-hotword’ with pid 61
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection r efused
[13:09:33.772541] INFO :audio_server::audio: Use input device: “default”
[13:09:34.313549] INFO :rumqtt::connection: $$$ Connected to broker
snips_stt --use-energy=false --num-mel-bins=40 --num-ceps=40 --low-freq=20 --hig h-freq=-400 --sample-frequency=16000
[13:09:34.560997] INFO :snips_asr: Loaded model from /usr/share/snips/asr
[13:09:34.565454] INFO :rumqtt::connection: $$$ Connected to broker
[13:09:34.568498] INFO :snips_asr : Idle
2017-07-15 13:09:35,571 INFO success: snips-hotword entered RUNNING state, proce ss has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:36,583 INFO spawned: ‘snips-dialogue’ with pid 86
[13:09:36.612904] INFO :snips_dialogue: Loading the configuration file
[13:09:36.665460] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:36,668 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:39,694 INFO spawned: ‘snips-dialogue’ with pid 87
[13:09:39.718831] INFO :snips_dialogue: Loading the configuration file
[13:09:39.771854] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:40,780 INFO success: snips-dialogue entered RUNNING state, proc ess has stayed up for > than 1 seconds (startsecs)
2017-07-15 13:09:40,781 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:41,793 INFO spawned: ‘snips-dialogue’ with pid 88
[13:09:41.836956] INFO :snips_dialogue: Loading the configuration file
[13:09:41.898408] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:41,900 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:42,915 INFO spawned: ‘snips-dialogue’ with pid 89
[13:09:42.950602] INFO :snips_dialogue: Loading the configuration file
[13:09:43.008094] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:43,011 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:45,019 INFO spawned: ‘snips-dialogue’ with pid 90
[13:09:45.047290] INFO :snips_dialogue: Loading the configuration file
[13:09:45.107289] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:45,112 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:48,122 INFO spawned: ‘snips-dialogue’ with pid 91
[13:09:48.152341] INFO :snips_dialogue: Loading the configuration file
[13:09:48.205760] ERROR:snips_dialogue: DialogueError(Serde(ErrorImpl { code: Me ssage("missing field name"), line: 1073, column: 9 }), State { next_error: Non e })
2017-07-15 13:09:48,211 INFO exited: snips-dialogue (exit status 1; not expected )
2017-07-15 13:09:49,214 INFO gave up: snips-dialogue entered FATAL state, too ma ny start retries too quickly
[13:09:54.821112] INFO :snips_hotword : Hotword detected
[13:10:19.661230] INFO :rumqtt::connection: $$$ Connected to broker
[13:10:19.664231] INFO :snips_queries : Idle
