So after the .70 update, Hass doesn’t seem to respond or execute MQTT commands from Snips.
Watching MQTT on Snips, the commands are heard correctly, but I’m seeing “The session was ended because one of the component didn’t respond in a timely manner.”
Any ideas? I’ve restarted, restarted MQTT, other than the update, nothing has changed.
I’ve experienced the same thing. Any luck on a fix?
No, I’m on .70.1 now and it’s still not working.
I just installed the Snips Addon, hassio 70.1, and I dont experience problems. Everything works!
I haven’t tried the Hassio add-on in a while. I had it working, but split it off to a different RaspberryPi because of the performance. The issue I’m seeing is with an external Snips talking to Hassio via MQTT. It appears to be something with the MQTT add-on for Hassio disconnecting the Snips client, but I’m not sure why.
