Snips not working, no voice capture
Hi I installed Snips on Hass.io. I can activate it by saying “hey snips” but it does not recorde my voice (or something). When I look in the logs, there is no transcribe of what I said nor any intents.
Who knows what can be wrong?
my logs:
[00:04:12.418962] INFO :reqwest::response: Response: ‘201 Created’ for https://atomic.snips.ai/v1/billing
2017-08-22 00:04:12,419 INFO success: snips-tts entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,421 INFO success: snips-dialogue entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,421 INFO success: snips-asr entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,421 INFO success: snips-analytics entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,422 INFO success: snips-hotword entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,422 INFO success: snips-audio-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2017-08-22 00:04:13,422 INFO success: snips-queries entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
1503353055: New connection from 127.0.0.1 on port 1883.
1503353055: New client connected from 127.0.0.1 as mqttc_2380990465 (c1, k5).
[00:04:15.514359] INFO :rumqtt::connection: $$$ Connected to broker
[00:04:15.517461] INFO :snips_queries : Idle
[00:04:31.562907] INFO :snips_dialogue::services: publish ASR(ToggleOff)
[00:04:31.563071] INFO :snips_dialogue::services: publish Hotword(ToggleOn)
[00:04:51.563015] INFO :snips_dialogue::dialogue: Timeout is reached. Going to Idle mode
[00:04:51.563158] INFO :snips_dialogue::services: publish ASR(ToggleOff)
[00:04:51.563245] INFO :snips_dialogue::services: publish Hotword(ToggleOn)
[00:04:56.297479] INFO :snips_hotword : Hotword detected
[00:04:56.324988] INFO :snips_dialogue::dialogue: State: Idle, incoming Message: Hotword(Detected)
[00:04:56.325132] INFO :snips_dialogue::services: publish Hotword(Wait)
[00:04:56.325213] INFO :snips_dialogue::services: publish ASR(ToggleOn)
[00:04:56.325280] INFO :snips_dialogue::services: publish AudioServer(PlayFile)
[00:04:56.325341] INFO :snips_dialogue::dialogue: Current State: WaitingQuery
[00:04:56.414339] INFO :snips_asr : Listening
[00:04:56.417196] INFO :snips_audio_server : using output “default” for “/usr/share/snips/dialogue/sound/start_of_input.wav”, WavSpec { channels: 2, sample_rate: 22050, bits_per_sample: 16, sample_format: Int }
LOG (snips_stt[5.2.48~1-3505]:CompileLooped():nnet-compile-looped.cc:336) Spent 0.110185 seconds in looped compilation.
[00:04:59.535061] INFO :snips_asr::asr : Endpoint detection.
[00:04:59.693345] INFO :snips_asr : Cleanup
[00:04:59.693456] INFO :snips_asr : Idle
[00:04:59.713456] INFO :snips_dialogue::dialogue: State: WaitingQuery, incoming Message: ASR(TextCaptured)
[00:04:59.713547] INFO :snips_dialogue::services: publish ASR(ToggleOff)
[00:04:59.713594] INFO :snips_dialogue::services: publish AudioServer(PlayFile)
[00:04:59.720794] INFO :snips_dialogue::services: publish NLU(Query)
[00:04:59.720906] INFO :snips_dialogue::dialogue: Current State: WaitingIntent
[00:04:59.764117] INFO :snips_analytics : Cleanup
[00:04:59.764223] INFO :snips_analytics : Idle
[00:04:59.767997] INFO :snips_audio_server : using output “default” for “/usr/share/snips/dialogue/sound/end_of_input.wav”, WavSpec { channels: 2, sample_rate: 22050, bits_per_sample: 16, sample_format: Int }
[00:04:59.779557] INFO :snips_queries : Cleanup
[00:04:59.779649] INFO :snips_queries : Idle
[00:04:59.813490] INFO :snips_dialogue::dialogue: State: WaitingIntent, incoming Message: NLU(IntentNotRecognized)
[00:04:59.813604] INFO :snips_dialogue::services: publish TTS(Say)
[00:04:59.813648] INFO :snips_dialogue::services: publish AudioServer(PlayFile)
[00:04:59.813690] INFO :snips_dialogue::dialogue: Current State: WaitingEndSpeaking(Idle)
2017/08/22 00:04:59 Received message Sorry I didn’t understand what you want
[00:04:59.866248] INFO :snips_audio_server : using output “default” for “/usr/share/snips/dialogue/sound/error.wav”, WavSpec { channels: 2, sample_rate: 44100, bits_per_sample: 16, sample_format: Int }
Ok(Response { status: Ok, headers: Headers { Server: nginx/1.11.1
, Date: Mon, 21 Aug 2017 22:04:59 GMT
, Content-Type: application/json
, Transfer-Encoding: chunked
, Connection: keep-alive
, Vary: Accept-Encoding
, Cache-Control: no-cache, no-store
, Access-Control-Allow-Origin: *
, Access-Control-Allow-Headers: X-Requested-With
, Access-Control-Allow-Methods: GET, POST, OPTIONS
, Access-Control-Allow-Credentials: true
, Access-Control-Max-Age: 1728000
, Access-Control-Expose-Headers: X-MP-CE-Backoff
, Content-Encoding: gzip
, }, version: Http11, url: “http://api.mixpanel.com/track/?data=eyJldmVudCI6InZvaWNlQ29tbWFuZCIsInByb3BlcnRpZXMiOnsiYXNzaXN0YW50TmFtZSI6IkhvbWUgQXNzaXN0YW50IiwiZGlzdGluY3RfaWQiOiIxNTgzZmIwZS04MGIwLTQ3MTAtYTJjNi02NzYzYzI3YzdhZTQiLCJlcnJvciI6ZmFsc2UsInN0dF9saWtlbGlob29kIjowLjAwMjQyMDU0MjUyODg1MjgyMDYsInN0dF9wcm9jZXNzaW5nU2Vjb25kcyI6My4yNzgwMDAxMTYzNDgyNjY4LCJzdHRfd29yZHNDb3VudCI6MiwidGltZSI6MTUwMzM1MzA5OSwidG9rZW4iOiI4OGNiNmFiNzkxYWNhMTRjNGI2NzlhOWUyNjJkMWY3MyJ9fQ%3D%3D&ip=1&verbose=1”, status_raw: RawStatus(200, “OK”), message: Http11Message { is_proxied: false, method: None, stream: Wrapper { obj: Some(Reading(ChunkedReader(chunk_remaining=unknown))) } } })
[00:04:59.903801] INFO :snips_analytics : Cleanup
[00:04:59.903890] INFO :snips_analytics : Idle
2017/08/22 00:05:02 Said Sorry I didn’t understand what you want
[00:05:02.772365] INFO :snips_dialogue::dialogue: State: WaitingEndSpeaking(Idle), incoming Message: TTS(SayFinished)
[00:05:02.772517] INFO :snips_dialogue::dialogue: Current State: Idle
[00:05:02.772578] INFO :snips_dialogue::services: publish ASR(ToggleOff)
[00:05:02.772648] INFO :snips_dialogue::services: publish Hotword(ToggleOn)
