Thanks. How do I figure out the baseoid for the UDM Pro? For WAN Bandwidth in and out.
Check my post above yours. Others and I have posted some pointers there. In short, find the ethernet ports and use an SNMP tool to plot the usage while doing a large, known download or speedtest.
@odwide
Iām quite new to working with templates and derivatives, but Iāve been doing my best to figure things out. Thanks to your code, Iāve managed to get most of the sensors working, except for the āWAN Down Usageā sensor, which is showing as unavailable. Hereās my YAML code. Iād really appreciate any assistance could be provided here.
- platform: snmp
name: "Optus WAN Interface Down Octets"
unique_id: optus_wan_interface_down_octets
host: 192.168.10.1
version: "3"
username: !secret isr_snmp_user
auth_key: !secret isr_snmp_auth_key
auth_protocol: "hmac-sha"
priv_key: !secret isr_snmp_priv_key
priv_protocol: "aes-cfb-128"
# ifHCInOctets G0/0/0.
# Running total of octects (Bytes) going into the interface since router reboot.
baseoid: 1.3.6.1.2.1.31.1.1.1.6.5
state_class: total_increasing
icon: mdi:cloud-download
unit_of_measurement: "B"
- platform: derivative
# Calculate the throughput by sampling the SNMP sensor
name: "Network - Optus WAN Down Throughput - Bps"
source: sensor.optus_wan_interface_down_octets
unit_time: s
round: 2
template:
- sensor:
- name: "Optus WAN Down Throughput"
unique_id: optus_wan_down_throughput
unit_of_measurement: Mbps
# Convert throughput derivative from Bps to Mbps
state: "{{ ((states('sensor.network_optus_wan_down_throughput_bps') | int) * 8 / 10**6) | round(1) }}"
state_class: measurement
- name: "Optus WAN Down Usage"
unique_id: wan_down_usage
unit_of_measurement: GiB
# Convert usage meter below from B to GiB
state: "{{ ((states('sensor.network_optus_wan_down_data_usage_meter_bytes') | int) / 2**30) | round(2) }}"
utility_meter:
network_optus_wan_down_data_usage_meter_bytes:
unique_id: network_optus_wan_down_data_usage_meter_bytes
name: Network - WAN Down Data Usage Meter - Bytes
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
Based on your yaml the correct entity id for Optus Wan Down Usage is sensor.wan_down_usage, not sensor.optus_wan_down_usage.
Thanks, I am new in HA world and still learning. Iāve updated the unique ID for Optus Wan Down Usage to something more descriptive. However, the sensor is still showing as unavailable, and I havenāt found any other sensors with āwanā in their names either.
- platform: snmp
host: 192.168.10.1
version: "3"
unit_time: s
round: 2
template:
- sensor:
unique_id: optus_wan_down_usage
utility_meter:
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
If network_optus_wan_down_data_usage_meter_bytes is giving the correct value then optus_wan_down_usage should too.
Apparently there are entities no longer being provided but that have id collision, since your sensor now has the id optus_wan_down_usage_3. To clean up, comment out the template for Optus WAN Down Usage, restart HA, under the Entities page search for any entity with id optus_wan_down_usage and delete it, uncomment the sensor in yaml and restart again. That should get rid of any all dangling sensors and leave only the one that will work.
Thanks, you gave the idea of double-checking the sensor ids. Unfortunately the id for network_optus_wan_down_data_usage_meter_bytes wasnāt created properly even it was specified correctly in the code. I fixed that things started to work!
Here is the working YAML code for someone who has implemented Double WAN on a supported router.
# Optus WAN Interface
- platform: snmp
host: 192.168.10.1
version: "3"
# Run following command to get the baseoid:
# snmpwalk -v3 -l authPriv -u <username> -a <auth_protocol> -A <auth_key> -x <priv_protocol> -X <priv_key> <host> <baseoid>
# example: snmpwalk -v3 -l authPriv -u isr_snmp_user -a hmac-sha -A !secret isr_snmp_auth_key -x aes-cfb-128 -X !secret isr_snmp_priv_key 192.168.10.1 1.3.6.1.2.1.31.1.1.1.6[.5]
unit_time: s
round: 2
- platform: snmp
name: "Optus WAN Interface Up Octets"
unique_id: optus_wan_interface_up_octets
host: 192.168.10.1
version: "3"
baseoid: 1.3.6.1.2.1.31.1.1.1.10.5
icon: mdi:cloud-upload
name: "Network - Optus WAN Up Throughput - Bps"
source: sensor.optus_wan_interface_up_octets
unit_time: s
round: 2
# Telstra WAN Interface
- platform: snmp
name: "Telstra WAN Interface Down Octets"
unique_id: telstra_wan_interface_down_octets
host: 192.168.10.1
version: "3"
baseoid: 1.3.6.1.2.1.31.1.1.1.6.6
name: "Network - Telstra WAN Down Throughput - Bps"
source: sensor.telstra_wan_interface_down_octets
unit_time: s
round: 2
- platform: snmp
name: "Telstra WAN Interface Up Octets"
unique_id: telstra_wan_interface_up_octets
host: 192.168.10.1
version: "3"
name: "Network - Telstra WAN Up Throughput - Bps"
source: sensor.telstra_wan_interface_up_octets
unit_time: s
round: 2
# Template
template:
# Optus WAN Interface Template
- sensor:
- name: "Optus WAN Up Throughput"
unique_id: optus_wan_up_throughput
state: "{{ ((states('sensor.network_optus_wan_up_throughput_bps') | int) * 8 / 10**6) | round(1) }}"
- name: "Optus WAN Up Usage"
unique_id: optus_wan_up_usage
state: "{{ ((states('sensor.network_optus_wan_up_data_usage_meter_bytes') | int) / 2**30) | round(2) }}"
# Telstra WAN Interface Template
- sensor:
- name: "Telstra WAN Down Throughput"
unique_id: telstra_wan_down_throughput
state: "{{ ((states('sensor.network_telstra_wan_down_throughput_bps') | int) * 8 / 10**6) | round(1) }}"
- name: "Telstra WAN Down Usage"
unique_id: telstra_wan_down_usage
state: "{{ ((states('sensor.network_telstra_wan_down_data_usage_meter_bytes') | int) / 2**30) | round(2) }}"
- name: "Telstra WAN Up Throughput"
unique_id: telstra_wan_up_throughput
state: "{{ ((states('sensor.network_telstra_wan_up_throughput_bps') | int) * 8 / 10**6) | round(1) }}"
- name: "Telstra WAN Up Usage"
unique_id: telstra_wan_up_usage
state: "{{ ((states('sensor.network_telstra_wan_up_data_usage_meter_bytes') | int) / 2**30) | round(2) }}"
# Utility Meter
utility_meter:
# Optus WAN Interface Utility Meter
name: Network - Optus WAN Down Data Usage Meter - Bytes
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
network_optus_wan_up_data_usage_meter_bytes:
unique_id: network_optus_wan_up_data_usage_meter_bytes
name: Network - Optus WAN Up Data Usage Meter - Bytes
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
# Telstra WAN Interface Utility Meter
network_telstra_wan_down_data_usage_meter_bytes:
unique_id: network_telstra_wan_down_data_usage_meter_bytes
name: Network - Telstra WAN Down Data Usage Meter - Bytes
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
network_telstra_wan_up_data_usage_meter_bytes:
unique_id: network_telstra_wan_up_data_usage_meter_bytes
name: Network - Telstra WAN Up Data Usage Meter - Bytes
cycle: monthly
offset:
hours: 72
minutes: 0
seconds: 0
Did you succeed with WAN in and Out with UDM Pro?
i think i am to blond for this.
Addded it in the configuration.yaml with the idea the sensors would popup, but i cant it working at all i might do something basicly wrong
