It wasn’t obvious how to achieve getting energy data from an APC PDU into home assistant’s new energy dashboard. Here is an example config I’m using for an APC PDU. It would be a nice feature enhancement to allow setting the device and state classes from the snmp sensor but for now via customize.yaml works!
configuration.yaml
- platform: snmp
host: sfpdu1.home
baseoid: 1.3.6.1.4.1.318.1.1.26.4.3.1.9.1
version: 2c
community: !secret snmp
unit_of_measurement: "kWh"
value_template: "{{((value | int) / 10)}}"
- platform: snmp
host: sfpdu1.home
baseoid: 1.3.6.1.4.1.318.1.1.26.4.3.1.5.1
version: 2c
unit_of_measurement: "watts"
value_template: "{{((value | int) * 10) | int}}"
customize.yaml
sensor.energy_rack:
device_class: energy
state_class: measurement
last_reset: '1970-01-01T00:00:00+00:00'
A few notes, the snmp values need to be adjusted as they measure either 10s watts or 0.1ths of a kWh, I do this with the value_template. The name for energy consumption sensors needs to start with energy_ at this time.
