Hi - having some trouble with my SNMP configuration.
Sample Config:
- platform: snmp
host: 192.168.0.###
community: <secret>
baseoid: 3.6.1.4.1.12325.1.1.2.1.1
baseoid is confirmed working.
I’m receiving the data and it seems to be working fine but not sure what is creating the error. I’m a HA enthusiast, not really a developer so can’t tell from the error log below.
I’ve been researching a bit and it looks similar to this older, closed issue but not sure.
Thoughts?
Thanks!
Error text from HA:
2017-10-29 21:19:22 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform snmp
File "/usr/lib/python3.6/site-packages/pyasn1/type/univ.py", line 1319, in prettyIn
tupleOfInts = tuple([int(subOid) for subOid in value if subOid >= 0])
File "/usr/lib/python3.6/site-packages/pyasn1/type/univ.py", line 1319, in <listcomp>
TypeError: '>=' not supported between instances of 'str' and 'int'
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 170, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 352, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/snmp.py", line 82, in setup_platform
ObjectType(ObjectIdentity(baseoid))))
File "/usr/lib/python3.6/site-packages/pysnmp/hlapi/asyncore/sync/cmdgen.py", line 111, in getCmd
lookupMib=options.get('lookupMib', True)))
File "/usr/lib/python3.6/site-packages/pysnmp/hlapi/asyncore/cmdgen.py", line 129, in getCmd
vbProcessor.makeVarBinds(snmpEngine, varBinds), __cbFun,
File "/usr/lib/python3.6/site-packages/pysnmp/hlapi/varbinds.py", line 39, in makeVarBinds
__varBinds.append(varBind.resolveWithMib(mibViewController))
File "/usr/lib/python3.6/site-packages/pysnmp/smi/rfc1902.py", line 845, in resolveWithMib
self.__args[0].resolveWithMib(mibViewController)
File "/usr/lib/python3.6/site-packages/pysnmp/smi/rfc1902.py", line 421, in resolveWithMib
self.__oid
File "/usr/lib/python3.6/site-packages/pysnmp/smi/view.py", line 206, in getNodeNameByOid
nodeName, mibMod['oidToLabelIdx'], mibMod['labelToOidIdx']
File "/usr/lib/python3.6/site-packages/pysnmp/smi/view.py", line 188, in __getOidLabel
nodeName[:-1], oidToLabelIdx, labelToOidIdx
[Previous line repeated 5 more times]
File "/usr/lib/python3.6/site-packages/pysnmp/smi/view.py", line 191, in __getOidLabel
resLabel = label + tuple([str(x) for x in suffix])
File "/usr/lib/python3.6/site-packages/pyasn1/type/univ.py", line 1249, in __add__
return self.clone(self._value + other)
File "/usr/lib/python3.6/site-packages/pyasn1/type/base.py", line 311, in clone
return self.__class__(value, **initilaizers)
File "/usr/lib/python3.6/site-packages/pyasn1/type/base.py", line 203, in __init__
value = self.prettyIn(value)
File "/usr/lib/python3.6/site-packages/pyasn1/type/univ.py", line 1323, in prettyIn
'Malformed Object ID %s at %s: %s' % (value, self.__class__.__name__, sys.exc_info()[1])
pyasn1.error.PyAsn1Error: Malformed Object ID (3, '6') at ObjectName: '>=' not supported between instances of 'str' and 'int'
