Hello all
Simply as the topic says, can I adjust the SNMP system monitoring polling interval?
Standard is, as far as I know, globally defined. I just want to set it up for SNMP to 3 minutes.
Thanks!
Regards, Lukas
Hello all
Thanks!
Regards, Lukas
I try to migrate my ICINGA config into HA. So, how to poll every 1-3 minutes?
See Entity component platform options https://home-assistant.io/docs/configuration/platform_options/#scan-interval.
cool, thanks
it Says ‘These options are being phased out and are only available for single platform integrations.’
So… If these options are being phased out, what is the new way of setting the polling interval?
link was updated - scan_interval from the entity options
So in your config, you use scan_interval
on every snmp sensor?
