I have a SNMP device, setup as a sensor: It returns “1” or “0” if my door is open or closed. I would like for this device to be setup as a Door in HA devices, for UI and for Alarm reasons. I have tried many ways I see in this forum, but none seem to work.
- I tried setting the device up as a binary_snesor: (in configuration.yaml) and that doesn’t work.
- I tried config > customizations, but since it is senser: not a binary_sensr: then “door” is not a option.
- I tried using a Template, but I can’t find how to do that in this situation.
I am using a daenetIP2 v2 to replace my old home alarm. I believe this device will be perfect if I can get past this problem. Thank you, very much, for any help.
