Snoozable Vacuum Schedule with Notification Control
Blueprint Contents
blueprint:
  name: Snoozeable Vacuum Schedule with Notifications
  description: |
    ## Description
    Automates vacuum scheduling via a [shedule helper entity](https://www.home-assistant.io/integrations/schedule/) and notifications, allowing control via notifications to pause, resume, snooze, or dock the vacuum.
    Notification functionality is triggered by vacuum state directly, so that changes made outside of this automation will still be reflected in the notifications.
    This blueprint also includes a snooze feature to temporarily pause the vacuum for a specified duration.
    Tested on Shark RV1000A with the official SharkIQ integration.
    ## Features
    - Start vacuuming when a schedule is triggered
    - Send notifications when the vacuum is cleaning, paused, or returning to dock
    - Pause, resume, snooze, or dock the vacuum from a notification
    - Snooze the vacuum for a specified duration based on an input_number helper
    - Automatically clear notifications when the vacuum is docked
    ## Requirements
    - A vacuum entity
    - A schedule entity
    - A timer entity
    - A notify service
    - (Optional) An input_boolean to enable/disable the schedule
    - (Optional) An input_number helper to dynamically set the snooze duration
    ## More Information
    ### Triggering the Vacuum
    The vacuum will start when the schedule is triggered, unless the input_boolean to enable the schedule is set to off. This can be used to disable the schedule while preserving the notification functionality of the automation.
    This blueprint will also still provide mobile app notifications when the vacuum is paused, snoozed, or returning to the dock, regardless of the source of the action.
    ### Snoozing the Vacuum
    If the vacuum needs to be temporarily paused, this blueprint allows the vacuum to be snoozed for a specified duration using a timer entity. Starting the timer will stop the vacuum, while finishing the timer will resume the vacuum. By either resuming, pausing, or returning to the dock (via any trigger, manual or otherwise), the vacuum will cancel the snooze timer.
    The vacuum can be snoozed for a specified duration either by setting the snooze_duration_default or by using an input_number helper to dynamically set the snooze duration. The snooze duration is in minutes and will be converted to seconds for the timer.
    The snooze duration can either be set to a fixed value when configuring the automation or by using an input_number helper to dynamically set the snooze duration. The input helper, if provided, will take precedence over the default snooze duration set in the blueprint input.
    ### Notifications
    In order to send notifications you must provicde a notify service to call. This typically will be notify.mobile_app_<device_name> for mobile app notifications. It is recommended to make use of [Notify Groups](https://www.home-assistant.io/integrations/group/#notify-groups) to send to multiple devices, or to insulate against breaking changes in the future by simply updating the groups as devices change over time.
    Notifications are sent when the vacuum is cleaning, paused, or returning to the dock. The notification will include actions to pause, resume, snooze, or dock the vacuum depending on the current state. The notification tag can be set to avoid conflicts with other notifications, while updating existing notifications that may already exist on the given device.
    The blueprint sends notifications that are both persistent and sticky, meaning they will remain on the device until manually dismissed. The notification will also include a clickAction to open the vacuum entity in the Home Assistant app. See the docs for [persistent](https://companion.home-assistant.io/docs/notifications/notifications-basic/#persistent-notification) and [sticky](https://companion.home-assistant.io/docs/notifications/notifications-basic/#sticky-notification) notifications for more information.
    A unique tag per automation should be used so that a given notification can be both updated and avoid conflicts with other vacuums. By default, the tag will inlude the vacuum entity id (without the domain) in order to provide uniqueness. This can be overridden by setting the notify_tag input. See [here](https://companion.home-assistant.io/docs/notifications/notifications-basic#replacing) for more information on replacing notification content.
    The persistent notification is cleared automatically when the vacuum returns to a docked state.
    ### Pausing
    A note on pausing: this automation calls `vacuum.stop` instead of `vacuum.pause`. This is because some vacuums do not support pausing and will instead stop the vacuum and return it to the dock.
  domain: automation
  author: travipross
  homeassistant:
    min_version: 2024.6.0
  input:
    vacuum_entity_id:
      name: Vacuum to Control
      description: The vacuum entity to control
      selector:
        entity:
          domain: vacuum
    snooze_duration_default:
      name: Snooze Duration (Minutes)
      description: The default snooze duration in minutes. Will be overridden by the snooze_duration_helper if set.
      selector:
        number:
          min: 5
          max: 120
          unit_of_measurement: min
      default: 30
    snooze_timer:
      name: Snooze Timer Entity
      description: The timer entity to use for snoozing the vacuum
      selector:
        entity:
          domain: timer
    schedule:
      description: The schedule entity to trigger the vacuum. Trigger will activate at the beginning of the scheduled event(s).
      selector:
        entity:
          domain: schedule
    notify_service:
      name: Notify Service Name
      description: The service to use for notifications, I.e. notify.<service_name>. **Do not include the `notify.` prefix**.
      selector:
        text:
    advanced:
      icon: mdi:cog
      description: These settings are optional and can be left blank if not needed.
      collapsed: true
      input:
        enable_schedule:
          name: Enable Schedule Helper (Optional)
          description: The input_boolean to enable/disable the scheduled cleaning. This can be used to disable the schedule while preserving the notification functionality of the automation.
          selector:
            entity:
              domain: input_boolean
          default: []
        snooze_duration_helper:
          name: Snooze Duration Helper (Optional)
          description: A helper input_number to set the snooze duration in minutes. This overrides the snooze_duration_default.
          selector:
            entity:
              domain: input_number
          default: []
        notify_tag:
          name: Notify Tag (Optional)
          description: The tag to use for notifications. See [here](https://companion.home-assistant.io/docs/notifications/notifications-basic#replacing) for more information. Consider using templates with unique identifiers to avoid conflicts with other notifications.
          default: ""
          selector:
            text:
trigger_variables:
  vacuum_entity_id: !input vacuum_entity_id
  vacuum_entity_id_stripped: "{{ vacuum_entity_id | regex_replace(find='^vacuum\\.', replace='') }}"
  helper_schedule: !input schedule
  helper_schedule_enable: !input enable_schedule
  snooze_timer: !input snooze_timer
triggers:
  - alias: "Schedule: cleaning event started"
    trigger: state
    entity_id:
      - !input schedule
    to: "on"
  - alias: "Snooze timer: started"
    trigger: event
    event_type: timer.started
    event_data:
      entity_id: !input snooze_timer
  - alias: "Snooze timer: finished"
    trigger: event
    event_type: timer.finished
    event_data:
  - alias: "Notification action: \"Snooze\" received"
    trigger: event
    event_type: mobile_app_notification_action
    event_data:
      action: snooze-{{ vacuum_entity_id_stripped }}
  - alias: "Notification action: \"Dock\" received"
    trigger: event
    event_data:
      action: dock-{{ vacuum_entity_id_stripped }}
  - alias: "Notification action: \"Pause\" received"
    trigger: event
    event_data:
      action: pause-{{ vacuum_entity_id_stripped }}
  - alias: "Notification action: \"Resume\" received"
    trigger: event
    event_data:
      action: resume-{{ vacuum_entity_id_stripped }}
  - alias: "Vacuum state: became docked"
    trigger: state
    entity_id:
      - !input vacuum_entity_id
    to: docked
  - alias: "Vacuum state: began cleaning"
    trigger: state
    entity_id:
    to: cleaning
  - alias: "Vacuum state: became idle"
    trigger: state
    entity_id:
    to: idle
  - alias: "Vacuum state: became returning to dock"
    trigger: state
    entity_id:
    to: returning
conditions: []
actions:
  - variables:
      vacuum_friendly_name: "{{ state_attr(vacuum_entity_id, 'friendly_name') }}"
      snooze_duration_helper: !input snooze_duration_helper
      snooze_duration_default: !input snooze_duration_default
      snooze_duration: "{% if snooze_duration_helper %}{{ states(snooze_duration_helper) | int * 60}}{% else %}{{ snooze_duration_default * 60 }}{% endif %}"
      notify_service: !input notify_service
      notify_tag_input: !input notify_tag
      notify_tag: "{% if notify_tag_input %}{{ notify_tag_input }}{% else %}vacuum-{{ vacuum_entity_id_stripped }}{% endif %}"
  - choose:
      - conditions:
          - condition: trigger
            id:
              - schedule_start
              - snooze_finished
              - action_resume
        sequence:
          - condition: not
            conditions:
              - condition: and
                conditions:
                    id:
                      - schedule_start
                  - condition: template
                    value_template: "{{ states(helper_schedule_enable) == 'off' }}"
          - action: vacuum.start
            metadata: {}
            data: {}
              entity_id: "{{ vacuum_entity_id }}"
      - conditions:
            id:
              - snooze_started
        sequence:
          - action: vacuum.stop
            metadata: {}
            data: {}
      - conditions:
            id:
              - vacuum_started
        sequence:
          - action: timer.cancel
            metadata: {}
            data: {}
              entity_id: "{{ snooze_timer }}"
          - action: notify.{{ notify_service}}
            metadata: {}
              title: "{{ vacuum_friendly_name }} Cleaning"
              message: Vacuum has started cleaning
                ttl: 0
                priority: high
                actions:
                  - action: pause-{{ vacuum_entity_id_stripped }}
                    title: Pause
                  - action: snooze-{{ vacuum_entity_id_stripped }}
                    title: Snooze
                  - action: dock-{{ vacuum_entity_id_stripped }}
                    title: Dock
                tag: "{{ notify_tag }}"
                sticky: true
                persistent: true
                notification_icon: mdi:robot-vacuum
                clickAction: entityId:{{ vacuum_entity_id }}
            alias: Send "Running" notification
      - conditions:
            id:
              - vacuum_idle
        sequence:
            metadata: {}
              title: >-
                {{ vacuum_friendly_name }} {% if states(snooze_timer) ==
                'active' %}Snoozed{% else %}Paused{% endif %}
              message: >
                {% if states(snooze_timer) == "active" %}
                Vacuum snoozed until {{ state_attr(snooze_timer,
                'finishes_at') | as_timestamp | timestamp_custom('%I:%M %p',
                local=true) }}
                {% else %}
                Vacuum paused
                {% endif %}
                ttl: 0
                priority: high
                actions:
                  - action: resume-{{ vacuum_entity_id_stripped }}
                    title: Resume
                  - action: >-
                      {% if states(snooze_timer) == 'active' %}pause{%
                      else %}snooze{% endif %}-{{ vacuum_entity_id_stripped }}
                    title: >-
                      {% if states(snooze_timer) == 'active' %}Pause{%
                      else %}Snooze{% endif %}
                    title: Dock
                sticky: true
                persistent: true
            alias: Send "Paused" notification
      - conditions:
            id:
              - vacuum_returning
        sequence:
            metadata: {}
            data: {}
            metadata: {}
              title: "{{ vacuum_friendly_name }} Returning to Dock"
              message: Vacuum returning to docking station
                ttl: 0
                priority: high
                actions:
                    title: Pause
                    title: Resume
                    title: Snooze
                sticky: true
                persistent: true
            alias: Send "Returning" notification
      - conditions:
            id:
              - vacuum_docked
        sequence:
            metadata: {}
            data: {}
            metadata: {}
              message: clear_notification
                ttl: 0
                priority: high
            alias: Clear notification
      - conditions:
            id:
              - action_dock
        sequence:
          - action: vacuum.return_to_base
            metadata: {}
            data: {}
      - conditions:
            id:
              - action_pause
        sequence:
            metadata: {}
            data: {}
            metadata: {}
            data: {}
            metadata: {}
              title: >-
              message: >
                local=true) }}
                {% else %}
                Vacuum paused
                {% endif %}
                ttl: 0
                priority: high
                actions:
                    title: Resume
                  - action: >-
                    title: >-
                    title: Dock
                sticky: true
                persistent: true
      - conditions:
            id:
              - action_snooze
        sequence:
          - action: timer.start
            metadata: {}
              duration: "{{ snooze_duration }}"
            metadata: {}
              title: >-
              message: >
                local=true) }}
                {% else %}
                Vacuum paused
                {% endif %}
                ttl: 0
                priority: high
                actions:
                    title: Resume
                  - action: >-
                    title: >-
                    title: Dock
                sticky: true
                persistent: true
mode: queued
max: 5
Description
Automates vacuum scheduling via a shedule helper entity and notifications, allowing control via notifications to pause, resume, snooze, or dock the vacuum.
Features
  • Start vacuuming when a schedule is triggered
  • Send notifications when the vacuum is cleaning, paused, or returning to dock
  • Pause, resume, snooze, or dock the vacuum from a notification
  • Snooze the vacuum for a specified duration based on an input_number helper
  • Automatically clear notifications when the vacuum is docked
Requirements
  • A vacuum entity
  • A schedule entity
  • A timer entity
  • A notify service
  • (Optional) An input_boolean to enable/disable the schedule
  • (Optional) An input_number helper to dynamically set the snooze duration
More Information
Snoozing the Vacuum
Notifications
In order to send notifications you must provicde a notify service to call. This typically will be notify.mobile_app_<device_name> for mobile app notifications. It is recommended to make use of Notify Groups to send to multiple devices, or to insulate against breaking changes in the future by simply updating the groups as devices change over time.
The blueprint sends notifications that are both persistent and sticky, meaning they will remain on the device until manually dismissed. The notification will also include a clickAction to open the vacuum entity in the Home Assistant app. See the docs for persistent and sticky notifications for more information.
A unique tag per automation should be used so that a given notification can be both updated and avoid conflicts with other vacuums. By default, the tag will inlude the vacuum entity id (without the domain) in order to provide uniqueness. This can be overridden by setting the notify_tag input. See here for more information on replacing notification content.
Pausing
A note on pausing: this automation calls vacuum.stop instead of vacuum.pause. This is because some vacuums do not support pausing and will instead stop the vacuum and return it to the dock.
