Hi, my SNZB-01P SONOFF Button has no action function anymore. Is it broken?
Did you read the v2.0 breaking changes? https://github.com/Koenkk/zigbee2mqtt/discussions/24198
Your sensor.xxx_action is now called event.xxx
You can go back to the previous method (though not recommended) by enabling the HA legacy options in your z2m config.
Hi, actually no. I think i missed that.
So my automation should now look like this, right?
automation:
- alias: Respond to button click
triggers:
- trigger: state
entity_id: event.taster_01
to: ~
conditions:
- condition: template
value_template: "{{trigger.from_state.state != 'unavailable'}}"
value_template: "{{trigger.to_state.attributes.event_type == 'single'}}"
actions:
- action: light.toggle
entity_id: light.schlafzimmer_deckenlicht
But i get the error Message malformed: extra keys not allowed @ data[‘automation’]
Hi, for my button, I use the following template condition. Maybe see if yours should be same for the unavailable test
There’s some good advice on using the new triggers here: Why and how to avoid device_ids in automations and scripts - #34 by 123
