SNZB-04P problem
Greetings to the group, this is my first post, so please forgive me if I am in the wrong place, asking the wrong question or just being dense.
I am a HA newbie and so far everything seems to have worked without too much thinking, until…I added a Sonoff SNZB-04P to my ZBBridge-P. The sensor shows “12 seconds ago” when it should show Open or Closed.
Does anybody have this door/window sensor working properly or does anybody else have the same problem? How do I get this fixed?
Look at the state in developer - state not in the recorder running log.
Open your Home Assistant instance and show your state developer tools.
What Zigbee stack are you using ? Ewelink, ZHA, Zigbee2MQTT, Zigbee2Tasmota ?
Ewelink.
Sonoff LAN v3.7.3 via HACS which says the “SONOFF SNZB-04 - ZigBee Wireless door/window sensor” has been tested via cloud.
I suggest you open an issue here:
The issue is already there. I added some details but as a new very basic user, I’m not sure if I supplied the info needed for someone to troubleshoot.
This is what I found. Very puzzled by the “device_class:timestamp”!
subDevId: 6410eafefff410347003
parentid: 1002061833
fwVersion: 2.2.0
battery: 100
trigTime: 1720200802000
supportPowConfig: 1
subDevRssi: -61
lock: 0
device_class: timestamp
friendly_name: SNZB-04P
Is it worth mentioning that both devices work perfectly in Ewelink and Alexa?
Both devices are new releases.
I have the same problem too!
There’s another thread about this, and I just replied with some indications on how to make it work before it gets fixed on ZHA : Sonoff SNZB-04P strangeness - #4 by hadb
