I’m struggling to understand how to connect this sensor to homeassistant. I have zigbee2mqtt with a SONOFF Universal Zigbee 3.0 USB Dongle as the coordinator.
Pressing and holding the pair button does result in the light flashing red but it is not interviewed by Z2M
What exactly are you trying to accomplish? Are you setting up multiple Z2M networks or do you want to use it as a router to extend your existing Z2M network. It’s not something you add to Z2M. It’s setup in the add on. Just like you originally set it up your Sonoff USB Zigbee coordinator.
Get it on the network, find the IP then go to it in a.browsed and update the firmware would be my first step. If spits out the Z2M configuration for you. If you don’t have Poe then you can power it via USB and plug an Ethernet cable into it
I have Permit Join set already but it’s not pairing. Are you speaking from experience of using this particular sensor or just basing it on standard process for joining zigbee devices?
Me too. I completely misread that and never even once notice the name difference. Probably due to a lot of SLZB-06 threads or questions and I thought “p” just meant the Zigbee chip type. So obviously disregard my previous post as I was way off on what was trying to be accomplished with what device.
