So confused - light is missing after ignoring integration
I installed Nanoleaf light panels yesterday and they were working great with HomeAssistant on the dashboard, automations, etc. The setup guide says to not configure it via Home Kit, but instead let discovery do the work. Because of this, I hit “Ignore” since it kept telling me Nanoleaf panels were discovered. This messes things up thought I guess and removed the entity. I figured out how to un-ignore the integration, and I see that Nanoleafs are being found (via Homekit) but I do not see the entity on my dashboard or anywhere else. I’ve looked at disabled entities and can’t find it. I’m not sure how to get the entity back. The configuration is the same, and I tried removing config, re-starting, and re-adding it again but no luck.
Any help is greatly apprecaited.
I solved it, I’m not sure how… there was a warning in config because I had a few different “light” items listed but separately and not under one “light” (like this: Problem - Duplicated Mapping Key Platform). Im not sure if that fixed it or not but Im glad its working now.
