SO counter with persistant memory module
Hello i wrote a interface to communicate with a library to make use of FRAM modules.
i think my ESPHome file could be much more compacter. please give some advice on it.
the files are on github GitHub - ageurtse/ESP-Home-SO-counter-with-persistant-memory-module: Make use of an I2C FRAM memory module to hold the latest sensor value in case of a power failure.
and of course the code i have so far.
substitutions:
  devicename: 102-fram
  friendly_name: SOSensor
  staticip: 192.168.1.102
esphome:
  includes:
    - "i2cfram/i2cfram.h"
  libraries:
    - "Wire"
#The develop isn't neccesary if version 0.4.3 is released, as of know it is stil in development stage.
    - https://github.com/RobTillaart/FRAM_I2C.git#develop
#load the valuw from memory on boot and store it in a global variabel
  on_boot:
    priority: 800.0
    then:
      - lambda: |-
          id(counter1) = readfromfram(0x01);
#global counter for total usage
globals:
  - id: counter1
    type: float
#select here your board type
esp8266:
  board: d1_mini
# Enable debug logging
logger:
  level: DEBUG
#Setup your WiFi
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pwd
  ap:
    ssid: "${devicename} Hotspot"
    password: !secret esphome_pwd
  manual_ip:
    static_ip: $staticip
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable Captive portal
captive_portal:
#enable ota
ota:
  password: !secret esphome_ota
#start the webserver
web_server:
  port: 80
# Enable Home Assistant API
api:
  password: !secret esphome_api
  reboot_timeout: 0s
  # Make it possible to set the initial value from withing HomeAssistant
  services:
    - service: set_total_power_in_kwh
      variables:
        new_addres: int # This is where in the fram memory the data is stored, each adres takes 8 bytes of memory, this is done in the custom component
        new_total_power_in_kwh: float # This is the value that should be stored in memory
      then:
        - lambda: |-
            id(counter1) = new_total_power_in_kwh/0.0005;
            writetofram(new_addres,id(counter1));
#settings for the I2C bus
i2c:
  - id: bus_a
    sda: GPIO4
    scl: GPIO5
    scan: true
#Enabeling the I2CFram module
custom_component:
  components:
    - id: my_fram
  lambda: |-
    auto my_fram = new MyFram(0x50);
    App.register_component(my_fram);
    return {my_fram};
# restart button voor de s0tool
button:
  - platform: restart
# A puls_counter to measure the curent power usage, it updates every 60 seconds.
  - platform: pulse_counter
    pin:
      number: D5
      mode:
        input: true
        pullup: true
    unit_of_measurement: "W"
    accuracy_decimals: 0
    update_interval: 60s
    name: "${friendly_name} Huidige verbruik"
    filters:
      - multiply: 0.03 # in my typical case 2000 pulses per kwh (60s/2000 pulses per kWh)
#a custom sensor to display the total amout of power usage.
    unit_of_measurement: "kWh"
    name: "${friendly_name} Totaal Verbruik"
    accuracy_decimals: 1
    lambda: return (id(counter1)* 0.0005 ); # (1/2000 pulses per kWh)
  - platform: uptime
    internal: true
text_sensor:
    name: "Uptime (formatted)"
    lambda: |-
      uint32_t dur = id(uptime_s).state;
      int dys = 0;
      int hrs = 0;
      int mnts = 0;
      if (dur > 86399) {
        dys = trunc(dur / 86400);
        dur = dur - (dys * 86400);
      if (dur > 3599) {
        hrs = trunc(dur / 3600);
        dur = dur - (hrs * 3600);
      if (dur > 59) {
        mnts = trunc(dur / 60);
        dur = dur - (mnts * 60);
      char buffer[17];
      sprintf(buffer, "%ud %02uh %02um %02us", dys, hrs, mnts, dur);
      return {buffer};
    icon: mdi:clock-start
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
    ssid:
      name: ESP Connected SSID
    mac_address:
      name: ESP Mac Wifi Address
#This is the input from which we are counting it is only for internal use
binary_sensor:
  - platform: gpio
    name: "${friendly_name} counter 1"
    pin:
      number: D5
      mode:
        input: true
        pullup: true
    internal: true
    #when there is a new puls, increment the global puls variable and write it to memory, only the pulse count is stored not the actual output.
    on_release:
      then:
        - lambda: |-
            id(counter1) += 1;
            writetofram(0x01,id(counter1));
