So I have an older HA docker install 2024.3.3 want to upgrade unsure if it safe to jump to the stable version
Hello there.
I have a Portainer stack which I’m wanting to update but kinda nervous to.
I know I’ve been negligent on updating this for about 8-9 months.
If I hit the "Update the stack " button will it just redo everyting and reboot it or will have to do other things as well…
version: ‘3’
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:2024.3.3" <--update to :stable
volumes:
- /etc/haconfig:/config
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
restart: unless-stopped
privileged: true
network_mode: host
Similar question referring to Proxmox setup:
Recommended to create a backup,
docker in my mind should be that easy to update but I am not running docker.
check the logs after update to see what went wrong
docker logs homeassistant
Before you do anything, backup
Stop stack
Change version
Start stack
As long as none of the breaking changes from 2024.3 to 2024.12 effect you it will start
Zwave must be latest version
HACS must be latest
Alternatively, you can slow roll the update
2024.3 >> 2024.4….2024.12
If there are breaking changes it will be more clear which version caused it
Generally with things i deem dangerous in docker I just rsync the files to another folder and start the container using the newly created folder. Just make sure the user/groups of the new folder match and so you don’t get errors related to that.
EDIT
macvlan in docker is better than host networking
My opinion
is there a complete list of releases?
and I just need to backup the CONF file stuff correct?
Yes. Make sure you get hidden folders. That’s why I recommend rsync
rsync -aP /config/* /config2/
I think that’s correct
thanks for this
