So Lost...unable to access HA interface...Proxmox console works
I don’t know what is going on. I have a system running Proxmox with HA installed per the fancy install script floating around here somewhere. When it finished the script, HA fired up and I had a brand new usable fresh install. I took a snapshot immediately.
Then, I attempted to restore some add-ons from my previous config, which it did, slowly, with some problems, like configuration settings for NodeRED, etc. Everything was working.
Earlier today we lost power to the building and the host restarted. Everything seemed to fire up without fail, but now, when I try to access https://192.168.2.100:8123, I get nothing. The VM is running, I can access the Home Assistant console and login as root, but I can’t seem to do anything from there.
SSH is not installed as an addon, so I have no idea how to edit configuration files from the ha> prompt. Any ideas?
Try
http://homeassistant.local:8123
That does nothing.
