Sock.send with hex sequence - solved
Team,
sorry for the dummy question but I continue to get an error.
Starting from the TCP component I modified it to send a sequence to the destination.
It works fine till when I try to send a special sequence.
I get this error:
2022-12-08 18:37:56.390 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.jvc_dila_sensor fails
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 527, in async_update_ha_state
await self.async_device_update()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 722, in async_device_update
raise exc
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/config/custom_components/jvc_dila/common.py”, line 153, in update
_LOGGER.warning(“6”,)
TypeError: a bytes-like object is required, not ‘str’
This is the latest code:
def update(self) -> None:
        """Get the latest value for this sensor."""
        _LOGGER.warning("0",)
        with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as sock:
            sock.settimeout(self._config[CONF_TIMEOUT])
            try:
                sock.connect((self._config[CONF_HOST], self._config[CONF_PORT]))
            except OSError as err:
                _LOGGER.error(
                    "Unable to connect to %s on port %s: %s",
                    self._config[CONF_PORT],
                    err,
                sock.close()
                return
            _LOGGER.warning("1",)
            readable, _, _ = select.select([sock], [], [], self._config[CONF_TIMEOUT])
            if not readable:
                _LOGGER.warning(
                    "Timeout (%s second(s)) waiting for a response after "
                    "sending to %s on port %s",
                    self._config[CONF_TIMEOUT],
                sock.close()
                return
            _LOGGER.warning("2",)
            value = sock.recv(1024).decode()
            """ debug log -> PJ_OK """
            _LOGGER.warning(
                "Input %s",
                value,
            _LOGGER.warning("3",)
            try:
                sock.send("PJREQ".encode())
                _LOGGER.error(
                    "Unable to send payload PJREQ on port %s: %s",
                    err,
                sock.close()
                return
            _LOGGER.warning("4",)
            if not readable:
                _LOGGER.warning(
                    "Timeout (%s second(s)) waiting for a response after PJREQ"
                sock.close()
                return
            _LOGGER.warning("5",)
            """ debug log -> PJACK """
            _LOGGER.warning(
                "Input %s",
                value,
            _LOGGER.warning("6",)
            try:
                sock.send(self._config[CONF_PAYLOAD].encode())
                _LOGGER.error(
                    err,
                sock.close()
                return
            _LOGGER.warning("7",)
            """ debug log -> Answer"""
            _LOGGER.warning(
                "Input %s",
                value,
            _LOGGER.warning("8",)
            sock.close()
            _LOGGER.warning("9",)
        value_template = self._config[CONF_VALUE_TEMPLATE]
        if value_template is not None:
            try:
                self._state = value_template.render(parse_result=False, value=value)
                return
            except TemplateError:
                _LOGGER.error(
                    "Unable to render template of %r with value: %r",
                    self._config[CONF_VALUE_TEMPLATE],
                    value,
                return
        self._state = value
Teh payload is:
DEFAULT_PAYLOAD: Final = "\x3F\x89\x01\x50\x57\x0A"
I tried to replace
with
                sock.send("\x3F\x89\x01\x50\x57\x0A")
I know it should be trivial but I’m not able to understand :slight_smile:
Found myself the answer, here if anyone needs it:
            buffer[0] = 0x3F
            buffer[1] = 0x89
            buffer[2] = 0x01
            buffer[3] = 0x50
            buffer[4] = 0x57
            buffer[5] = 0x0A
            try:
                sock.send(buffer)
                _LOGGER.error(
                    "Unable to send buffer on port %s: %s",
                    err,
                sock.close()
                return
