Getting this set of issues when attempting to upgrade from 0.33.3. Any ideas? I don’t have masses of free space, but should be enough to upgrade. I tried it a couple of times to be sure, but same message each time. My existing system is mostly working. Having some issues with emulated Hue. I was hoping there may be some fixes
Update: Still get this when trying to upgrade to 0.35
Cleaning up...
Exception:
File "/usr/share/python-wheels/urllib3-1.9.1-py2.py3-none-any.whl/urllib3/resp
onse.py", line 186, in read
data = self._fp.read(amt)
File "/usr/lib/python3.4/http/client.py", line 500, in read
return super(HTTPResponse, self).read(amt)
File "/usr/lib/python3.4/http/client.py", line 539, in readinto
n = self.fp.readinto(b)
File "/usr/lib/python3.4/socket.py", line 371, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.4/ssl.py", line 745, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.4/ssl.py", line 617, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 290, in ru
n
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python3/dist-packages/pip/req.py", line 1198, in prepare_files
do_download,
File "/usr/lib/python3/dist-packages/pip/req.py", line 1376, in unpack_url
self.session,
File "/usr/lib/python3/dist-packages/pip/download.py", line 572, in unpack_http_url
download_hash = _download_url(resp, link, temp_location)
File "/usr/lib/python3/dist-packages/pip/download.py", line 433, in _download_url
for chunk in resp_read(4096):
File "/usr/lib/python3/dist-packages/pip/download.py", line 421, in resp_read
chunk_size, decode_content=False):
File "/usr/share/python-wheels/urllib3-1.9.1-py2.py3-none-any.whl/urllib3/response.py", line 256, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/share/python-wheels/urllib3-1.9.1-py2.py3-none-any.whl/urllib3/response.py", line 201, in read
raise ReadTimeoutError(self._pool, None, 'Read timed out.')
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='pypi.python.org', port=443): Read timed out.
