Today I have connected my new Zigbee Tuya plant sensor via Zigbee to my HA setup via ZHA / Nabu Casa SkyConnect. HA does recognize the temperature and soil moisture sensors, but when I want to add the plant through the Integration Plant Monitor, this integration does not recognize any soil moisture sensor. Any idea how I can solve this?
Only entities that are of a device_class of moisture will appear in the soil moisture sensor dropdown when you are setting up your plant. You can leave that blank during set up.
Later, in Developer Tools → Actions, you can use the action plant.replace_sensor to update the moisture sensor to any sensor you want.
