Soil sensor integration TS0222 par _TZ3000_kky16aay
Hello all,
I think this topic was already touched, but I could not find an appropriate answer.
The problem is the following: I bought a soil sensor, ( this one: Sensor on Ali.
I can integrate it via zigbee and ZHA, but it wont give any value Everything reads “unavailable”. On the other hand , I could install an MQTT broker and have the correct readings, but that opens another can of worms, and several other sensor will stop working properly (Yes I tried that on a duplicate VM installations.
The question is: Can I make it work in ZHA?
To have ZHA and MQTT seems also quite complicated and I suspect it might also bring other issues.
Any idea welcome, as I fear that I hit my profile of incompetence here.
PS. The sensor works correctly with the phone app through a zigbee gateway.
Did you find a solution?
I just bought and received this sensor and I face the same problem : no data.
Sorry for the late answer. I just gave up, the sensor now exhausts the battery very quickly, I suppose the humidity goes in and finally, this is an (expensive) piece of junk.
I may try to develop something later. I am on something else right now.
