Solar-Assistant MQTT
Can someone point me in the right direction? When I follow the manual from Solar-Assistant to integrate with HA it works fine, but all other stuff depending on MQTT fail. Home Assistant broker setup with SolarAssistant
I think it has to do with mqtt user I created. How do I get the older devices to also use this new user?
I proceeded in such a way that on the original MQTT that was running here, I set the rest for SA and everything works as expected.
I didn’t create any new user.
According to the SA documentation, I started from
active: true
folder: mosquito
