Solar energy
Hi, I have solarpanels with an inverter named Eversolar. Reports every minute to homeassistant but I can’t get it adding to my enerygy panel.
So I made a helper to create an entity based on the Riemann som integrale sensor. That’s the only one which can transform electrical energy.
Unfortunatly it add’s an extra h to the power, so instead of having,per example, 10kWh, I get 10kWhh.
And the energydashboard does not recognize that kind of report.
The reason for this is that one can only choose for h (hour) or d (for days. And on top of that it gets added to the extension so it cannot be used in the result of energy use.
So, what I want to ask is this: make it possible to not only choose between t or d, but also nothing.
Thanks in advance
Hello sjeldon
unfortunally I cannot help you with your problem but I have a question. I have also some inverters from eversolar and I try to implement them to my HASS but still did not get it.
May you can help me / send some advice/ links?
BR
Mace
Hi, could you please share how you are getting the information out of the Eversolar inverter and into Home Assistant? Information on hardware required and configuration would be great.
Thanks.
