Solar.forecast curve not visible in solar production graph
If the Solar.forecast integration is configured, the forecast should appear in the solar production graph.
The forecast curve does not appear for me.
Does anyone have any idea what I need to do?
The data is basically there and the integration works.
If you edit the Energy Dashboard, and edit the Solar Production entity, is the forecast checkbox “checked”?
i have a similar problem and very noobish with homeassistant. :frowning:
Forecast.Solar integration is configured and running since days - the entitys are filled with data.
But i cant find (and add) the entitys in the Solar Production under the Energy Dashboard.
Even if i copy & paste the exact name. :frowning:
Did i miss something? Did i have to do something with the Forecast.Solar entitys? :thinking:
EDIT:
Nevermind - i just dont need to add a secound entity as forecast. Just switched to “forecast production” and now both is shown. :+1:
