How to reconfigure a solar forecast? Or how to delete (and later re-create) a solar forecast?
Background: While playing with the energy feature of HA I entered the wrong azimuth and wrong total production for a solar forecast. But now I am neither able to re-configure nor to delete/re-create it via the GUI of HA.
I am using HA 2022-11
in the devices/integration I only found the option to disable the forecast but no deletion nor configuration is possible.
@zoogara
Thank you so much! your hint. It helped me.
In the list of integrations the forecast wasn’t shown. but when I now added an integration for a solar forecast my current one was proposed. I re-configured it, and now it’s visible in the list of integrations as well.
Many thanks
oops, I have to correct myself. My action above: adding an integration of a solar forecast and using the proposal for the existing one led to the creation of a new solar forecast.
@zoogara you were right, the integration of the solar forecast was hidden. I can’t guess why it was hidden. Anyways, I found it, deleted it and should be happy now.
Thanks for your support.
