Solar gate with esp32 and relay
Successfully controlling garage door with status and now onto my K-2 solar gate. I am wanting to manually open/close the gate using cat 6 outdoor i had left over (~100 feet needed) and an esp32 using momentary relay in the house. I am unsure what size/type of relay needed to trigger the opening of the gate(power?) and if able to use the same “radio” and common terminal as the receiver. I considered tying into the solar power but know it would draw too much if using wifi. I am new to this but have accomplished a ton so far (controlling remote via relay) and apologies if this question answered already.
Thank you!!
Linear Model 109950 1-Channel, 12-24V, Gate Receiver in NO configuration:
“The operator supplies 12-24 volt power to the receiver, or the receiver can be powered by a separate AC power transformer or DC power supply. The normally open relay output can switch up to 1 amp @ 30 VAC”
Radio input diagram:
