I did scratch my head for quite a while wondering why you wanted to do this, rather than plot actual power, and then wondering how to go about doing it, but in the end it only took about five minutes to set up in apex charts.
First up - that is what ‘utility meters’ do. They record an ever increasing figure, and reset to zero every hour / day / week / month. The HA utility meter integration does this, and your inverter does it too. My inverter has a figure for total energy generated since it was first turned on, and a figure for this year, this month, today (as well as last year, last month, and yesterday). All done in the same way, track and reset on the hour / day / week / month / year. Not seen one for hourly yield before, but very easy to make one up.
As to plotting this on a sensible graph in Apex Charts card …
The secret seems to be
- use the standard ‘from history’ graph plot of the ‘hourly energy’ sensor
- group the data by (default) hour
- use a group transform function max to get the largest value for the hour
- use a series offset to shift the plot by 60 minutes to make the output timestamp match the end of the hour
This, rather to my surprise, works.
There is for me a question of how the default ‘hour’ grouping works, and I am assuming that this is over a given time-hour 00 to 59 minutes (not a rolling 60 minutes), so the max value will always be the final one just before the hourly reset. This value is placed into the hour ‘bucket’ and is plotted at the start of the hour, hence the two graphs appear out of step by 60 minutes. To make them match, I am using a series offset -60 minutes, however it might be more appropriate to use -30 minutes. The graphs would not match, but the bucket value for the hour (the one you want) would be plotted around the middle of the hour. Something to experiment with.
During the solar day, I have to use “entend_to: false” so as to stop the graph from plotting beyond the last point. The end point will start at zero each hour, and rise to the maximum value at the end of the hour, so the last plotted point is always going to be dynamic.
I only use Apex charts card so I can’t help you with plotly, but this is the configuration I used. Obviously you can remove the direct entity plot and adjust the span to tidy the graph.
type: custom:apexcharts-card
header:
show: true
title: Solar Hourly Yield - Experimental Card
show:
last_updated: true
graph_span: 24h
span:
start: day
series:
- entity: sensor.help_um_solar_by_hour
curve: smooth
show:
legend_value: false
extend_to: false
stroke_width: 1
color: blue
group_by:
func: max
offset: '-60min'
curve: smooth
show:
legend_value: false
extend_to: false
stroke_width: 2
color: orange
Since I think that you wanted a bar chart, here is what I finally ended up with. Looks quite good I think.
header:
show: true
show:
last_updated: true
graph_span: 17h
span:
start: day
offset: +5h
series:
type: column
group_by:
func: max
offset: '-60min'
color: orange
Hope that helps.
