Yes, of course:
[{"id":"9fc0f809.f00518","type":"tab","label":"disable-battery-discharging","disabled":false,"info":""},{"id":"69d3ebb87d314db0","type":"inject","z":"9fc0f809.f00518","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":240,"wires":[[]]},{"id":"b51f2c57b46cfdf3","type":"switch","z":"9fc0f809.f00518","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":610,"y":160,"wires":[["a824c7b1042d8991"],["269d4a791ea63c01"]]},{"id":"a824c7b1042d8991","type":"debug","z":"9fc0f809.f00518","name":"Zielladen nicht aktiv","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":80,"wires":[]},{"id":"832e19233b7c6bdf","type":"buffer-maker","z":"9fc0f809.f00518","name":"","specification":"spec","specificationType":"ui","items":[{"name":"float","type":"floatle","length":1,"dataType":"msg","data":"payload"}],"swap1":"swap16","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":870,"y":240,"wires":[["a5e2af6ad2457e4a"]]},{"id":"a5e2af6ad2457e4a","type":"buffer-parser","z":"9fc0f809.f00518","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint16be","name":"data","offset":0,"length":2,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":490,"y":340,"wires":[["67062c1ccec57ec9"]]},{"id":"67062c1ccec57ec9","type":"modbus-write","z":"9fc0f809.f00518","name":"1034 (Ent-/Ladeleistung)","showStatusActivities":false,"showErrors":true,"showWarnings":true,"unitid":"71","dataType":"MHoldingRegisters","adr":"1034","quantity":"2","server":"a1b432331279e425","emptyMsgOnFail":false,"keepMsgProperties":false,"delayOnStart":false,"startDelayTime":"","x":810,"y":360,"wires":[["85bf2b359a49c492"],[]]},{"id":"85bf2b359a49c492","type":"debug","z":"9fc0f809.f00518","name":"Zielladen aktiv","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1020,"y":320,"wires":[]},{"id":"f93eebac120801dc","type":"debug","z":"9fc0f809.f00518","name":"error","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":530,"y":40,"wires":[]},{"id":"035fe24f0538dc43","type":"mqtt in","z":"9fc0f809.f00518","name":"","topic":"evcc/loadpoints/1/planActive","qos":"2","datatype":"auto-detect","broker":"d6c82b6abc04c385","nl":false,"rap":true,"rh":0,"inputs":0,"x":280,"y":160,"wires":[["b51f2c57b46cfdf3"]]},{"id":"269d4a791ea63c01","type":"api-current-state","z":"9fc0f809.f00518","name":"","server":"8161678f.30be58","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.scb_battery_soc","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":480,"y":240,"wires":[["adeebeb74855588a"]]},{"id":"adeebeb74855588a","type":"switch","z":"9fc0f809.f00518","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"50","vt":"str"},{"t":"lt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":830,"y":140,"wires":[["b32a4111c8bebdbe"],["832e19233b7c6bdf"]]},{"id":"b32a4111c8bebdbe","type":"debug","z":"9fc0f809.f00518","name":"battery SoC > 50%","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1160,"y":160,"wires":[]},{"id":"a1b432331279e425","type":"modbus-client","name":"Kostal Plenticore","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":false,"tcpHost":"192.168.188.109","tcpPort":"1502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"71","commandDelay":"5","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":false},{"id":"d6c82b6abc04c385","type":"mqtt-broker","name":"","broker":"192.168.188.15","port":"1884","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"8161678f.30be58","type":"server","name":"Home Assistant","addon":true}]
You should be able to import this in node red and adapt for your needs
