I have the same issue:
The Energy-Tab has no Source for Battery-Input, only Home Consumption from Battery. This way it can’t be used. Also There seem to be no “power to the grid”, only Home Consumption from Grid". The Integration so far seem to only have “Consumption” Sources, but no “feeding” sources.
I mean, at some point, if there don’t exist any sources, they could be … calculated? Although I see the point, even if calculated, there is no way to differ, if the power is fed to grod or to battery … hmm … :-/ Maybe there are some stats more I don’t see so far?
Right now, I am looking for a way to disable battery discharging from automations (to avoid battery discharge while charging my car).
I was hoping to simply write to battery_min_soc, but that seems to be read only (despite the documentation marking it as RW)? Anyone has some idea? Thanks in advance!
I have issue with my Plenticore Plus.
Despite having smart meter integrated it does not show grid consumption/feed in.
Also, house consumption stays inactive at all times.
I am suspecting the electrician as already discovered… he did not install the meter as I have no battery (-:
Luckily I found it in pile of crap in the garage after they moved out of the building site.
That seems like a bongled installation of the meter, we had the issue, that the oven and stove were not being checked because they had been installed serially after the meter. The thing is the meter has to be the last thing in your actual connections and it has to be installed properly. Yours seems not to be.
Hello guys,
I had the same issue. Therefore thanks to the input from the Photovoltaikforum.de I have solved my problems with this Kostal Integration.
However I have created a video for this topic. In case you struggle just have a watch.
But it is in german language
any idea why it after last updates stopped working - i am still in my very beginnings with YAML and cant really diagnose why the Modbus KSEM stopped working - it just says, “not available”
Hi all,
I am using the Kostal integration. In one of the last versions a new switch appeared → switch.kostal_plenticore_plus_10_0_battery_strategy
I think it makes possible to switch between “automatic” and “automatic economic” or am I wrong? If I am right, what represence the on state and what the off state?
Hi, sorry to hijack this thread but i guess someone in here will have an answer for me
My old Goodwe inverter has died and i am looking for a new alternative.
As I hated not being able to get data form the old one i am looking for something with a Local api for home assistant integration, and the Kostal Plenticore 5,5 kW hybridinverter seems like a good option.
If i buy the Kostal Plenticore 5,5 kW hybridinverter unit, do i need anything else to get useful metrics for home assistant? I do not plan to add a battery to te system (at least not yet).
I saw some mention of a smart meter… Is that necessary to get correct data?
Where i live phase balancing is not required as the energy meter sums usage across all phases, and deducts my delivery to the grid at the given time.
Hello Palban,
not sure what you mean by manage a battery but you get many sensors to read and work with.
Also in the Energy Dashboard a battery can be included if I remember correclty.
