Solar-Log integration entities now partially without value after 2024.10
Hi all,
After updating to 2024.10, the Solar-Log integration does not show values for some of the entities anymore:
It looks like that new entities got created with _2 in the end which are now provided with the values.
Not sure why this happened now as I have done multiple updates and reboots without issues before.
Rebooting does not help here.
Any way to get the data back to the original entities?
Regards
Peter
Can’t you just rename them?
Hallo Peter,
hast Du dazu eine Lösung?
Bei mir geht Solarlog auch nicht mehr.
Hallo Tobi,
ich habe das Backup vor dem Update eingespielt und dann ging wieder alles.
Jetzt wird die 10.1 als Update angeboten. Ich weiß nicht, ob es das Problem behebt.
Möchte noch ein Issue auf GitHub erstellen.
VG
Peter
I haven’t tried this. But luckily now everything works again after I recovered from core backup before the update.
Not sure if update 10.1 would still cause same issue. So I think of raising an issue at GitHub.
There is already a GitHub issue now:
Left a comment there that I’m having same issue.
