Dear @Mahko_Mahko
Very nice post.
I was just testing you ESP Code. It is very nice!!!
I was wondering why you are using “input_boolean.defeat_sleep” with a helper and not a dedicated switch for this device?
Did you tried such a solution?
Regards
Adrian
Thanks!
I’ve refined the config more which I’ll repost soonish.
I was considering having both wake options.
The remote virtual switch doesn’t require any hardware.
A button/switch would need to be weatherproofed.
I may still add one.
I recall that a wake button is better than a wake switch. Something about it being hard to determine the true state of a switch on boot. Might be wrong though.
You’re welcome.
I was more thinking about a “remote” virtual switch on the device, and not created with a helper.
There where i have my switch Test.
Oh right I see.
The virtual switch can’t be on the device as when it is in deep sleep it will not track the state as changed in HA / retrieve the changed state when it wakes (I think).
I would prefer that but it doesn’t seem to work as you might want. Let me know if you find otherwise.
Till now, i couldn’t fine a solution.
Maybe someone else?
I will open a new Topic with this question.
Trying to repropagate a large jade branch cutting!
https://www.houzz.com/discussions/4766422/can-you-replant-or-propagate-a-large-jade-tree-branch
Underneath it’s just like this (it’s not the same as below but it is just a stump below soil)…! Hope it survives!
Interesting project. I just started something simular for my balcony. No plumbing and no power outlet.
I ordered some parts from Aliexpress. As for now it is enough for 8 plants, expandable to 16. I use a 8-relay board with onboard ESP, with an extra 8-relay board I can expand it to 16.
Each plant has it’s own micropump. The idea is to measure the moisture and when it’s on the minimum the according pump starts for a defined time to water it to the max level. I want to do that with some interruptions to get a more accurate measuring of the moisture level. The main hose comes from the tank, goes tot an 8-fold divider. From there there goes a hose to every pump.
I just received all the parts and programmed the ESP so it is visible in Home Assistant, so I’m not that far yet
Keep me posted on your project please.
I’m probably going to do another one when I finally finish this one that will service two plants, so keen to see your “multi plant solution”.
The new one will replace my old “beer dispenser” irrigation system;)
That’s a really nice way to do it with a beer pump
What type of sensor are you using for the waterlevel sensor in the tank?
The new system has a VL53L0X. I’m still working through some reliability issues. Might be connections. Stops reporting when battery voltage gets lower. But generally works well. Much smaller than an ultrasonic.
The old system doesn’t have anything. I got a float switch which I was going to use with an aqara reed switch but I never got around to installing it.
I think I was originally going to pop one of these in the bottom but the signal range didn’t seem to be good and I don’t think they’re really supposed to be immersed.
AU $23.31 48%OFF | Aqara Flood Sensor Water Immersing Sensor IP67 Waterproof Remote Alarm Work With Smart home app
https://a.aliexpress.com/_msHN9me
AU $2.18 | Thinary VL53L0X Time-of-Flight (ToF) Laser Ranging Sensor Breakout 940nm GY-VL53L0XV2 Laser Distance Module I2C IIC 3.3V/5V
https://a.aliexpress.com/_mPlpmvu
I’m not at that point yet, but I have to add one in my system as well. I’ll have a look at that one when I’m going to add one.
Rewired it with better quality wire and it seems to be ok now.
Thanks, I’ll keep that in mind
Can you share your button code from ha?
Which button do you mean?
I thought you were trying to add a button to the dashboard to stop deepsleep? I’m trying to figure out how to prevent my sensor node from going to sleep too do OTA updates when needed.
yeah my main way is based on this approach. You toggle on a HA control and next time it wakes and connects, it will stay awake.
The HA config is similar to this (think I’ve changed the name).
input_boolean:
keep_esps_awake_switch_ha:
name: "Keep ESPs Awake"
initial: false
icon: mdi:sleep-off
I’ll maintain my master config here. May not maintain it well though.
Edit: Fresh paste on 2024-01-13
#Todo:
#Determine night time battery loss.
#More testing insitu
#HA alerts for low water, low battery, data updates not working.
#Check pump runs.
#Monitor review wet/dry/battery thresholds.
#Make debugging sensors internal.
substitutions:
sleep_time: 60min
auto_wake_time: 20s
pump_run_time: 10s
internal_mode: "true"
long_deep_sleep_duration: 24h
bh1750_i2c_scl_blue: GPIO27
bh1750_i2c_sda_green: GPIO25
vl53l0x_i2c_scl_blue: GPIO23
vl53l0x_i2c_sda_green: GPIO05
power_peripheral_pin: GPIO26
pump_switch_pin: GPIO18
batt_voltage_pin: GPIO33
soil_moisture_pin: GPIO34
# G # RST #1 tx # G
# NC # VP #3 rx #@ 27 bh1750 blue scl ${bh1750_i2c_scl_blue}
# VN #@ 26 ${power_peripheral_pin} #22 #@ 25 bh1750 green sda ${bh1750_i2c_sda_green}
# 35 #@ 18 ${pump_switch_pin} #21 #@ 32
#@ 33 ${batt_voltage_pin} #@ 19 #27 # TDI
# 34 ${soil_moisture_pin} #@ 23 ${vl53l0x_i2c_scl_blue} #25 #@ 4
# TMS #@ 5 ${vl53l0x_i2c_sda_green} #G # 0
# NC # 3v3 #5v # 2
# SD2 # TCK #TDO # SD1
# CMD # SD3 #SDO # CLK
esp32:
board: ttgo-t7-v14-mini32 #pinout: https://ae01.alicdn.com/kf/Ha204b20d14d243faa0c1a8760de1b187r.jpg
esphome:
friendly_name: ESPlanty
comment: Balcony Solar Irrigation
on_boot:
# #Try this if sensors don't boot. https://community.home-assistant.io/t/add-sensor-delay-upon-power-on/158567/6?u=mahko_mahko
# https://community.home-assistant.io/t/i2c-bus-scan-after-deep-sleep-recovery/524925/7?u=mahko_mahko
- priority: 900
then:
- lambda: |-
Wire.begin();
delay(500);
- priority: -100
then:
#Reset sensor update counters. These are for debugging.
- lambda: id(count_irrigation_lux).publish_state(0);
- lambda: id(count_batt_voltage).publish_state(0);
- lambda: id(count_irrigation_tof).publish_state(0);
- delay: 1s
#Auto sensor updates are turned off and manually requested on boot. These are multi-sampled and then aggregated.
#The ESP then goes back to sleep when they're done (unless told to stay awake).
#Request sensor updates
- logger.log: "....Starting sensor updates"
- repeat:
count: 5 #Update cycles
then:
- component.update: batt_voltage #Battery level
- delay: 100ms
- component.update: soil_moisture_voltage #Moisture level
- delay: 100ms
- component.update: tof #Water tank level
- delay: 100ms
- component.update: irrigation_lux #Light level
- delay: 100ms
#second pass for ADC based sensors which benefit from more samples.
- delay: 200ms
- delay: 200ms
- delay: 100ms
on_shutdown: #Includes deep sleep
priority: -100
then:
- script.wait: run_pump_for_pump_run_time #Wait until pump run is done.
- if:
- binary_sensor.is_on: all_updates_recieved
then:
- logger.log: "Data updates ok..."
else:
- logger.log: "A sensor might be down...missing updates"
- binary_sensor.template.publish:
state: ON
- delay: 1s
- switch.turn_off: pump #Probably not required....
#Turn off 5v peripheral power. It will retore as on when it wakes.
- logger.log: "Turning off peripheral power..."
- switch.turn_off: power_peripherals
#Turn off the "Fresh data recieved sensors"
state: OFF
state: OFF
state: OFF
state: OFF
state: OFF
wifi:
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.1.123
gateway: 192.168.1.1
subnet: 255.255.255.0
api:
ota:
logger:
level: VERBOSE
baud_rate: 0
i2c:
- id: bh1750_i2c_bus
sda: GPIO25 #data > green wire
scl: GPIO27 #clock > blue wire
scan: true
- id: vl53l0x_i2c_bus
sda: ${vl53l0x_i2c_sda_green} #data > green wire
scl: ${vl53l0x_i2c_scl_blue} #clock > blue wire
scan: true
deep_sleep:
#Auto deep sleep shouldn't actually get used if data updates are happening properly (should sleep sooner).
#But if something is wrong with data updates this will kick-in to protect battery discharge.
run_duration: ${auto_wake_time}
sleep_duration: ${sleep_time}
time:
- platform: homeassistant
on_time:
#Deep sleep at 8pm and wake up at 6am.
- hours: 20
then:
#Publish battery level to the end of day sensor since it will be our last update.
- lambda: return id(end_of_day_battery_percent).publish_state(id(batt_level).state);
#Reset culmulative light sensor reset
- sensor.integration.reset: irrigation_cul_lux_hours
- delay: 1s
#Rest up
- deep_sleep.enter:
until: "06:00:00"
time_id: esptime
text_sensor:
# Reports the ESPHome Version with compile date
- platform: version
select:
#Watering Mode.
#Watering regime allows plant to become quite dry and then get a good watering,
#as opposed to more frequent bang bang watering cycles.
#TODO: More testing.
optimistic: true
restore_value: true
options:
- Wetting Mode
- Drying Mode
initial_option: Drying Mode
number:
#Upper mositure target (once dry)
name: Moisture Upper Target
icon: mdi:arrow-collapse-up
optimistic: true
unit_of_measurement: '%'
min_value: 40.0
max_value: 90.0
step: 5.0
restore_value: true
initial_value: 80.0
#Lower Water threshold (triggers watering regime). Need to establish good values.
name: Moisture Lower Threshold
icon: mdi:arrow-collapse-down
optimistic: true
min_value: 5.0
max_value: 60.0
step: 5.0
restore_value: true
initial_value: 50.0
#Battery Saving Mode Threshold. Trigger longer sleep cycles if below this and hope for sunlight.
name: Battery Saving Threshold
icon: mdi:battery-alert
optimistic: true
min_value: 10.0
max_value: 80.0
step: 5.0
restore_value: true
initial_value: 20.0
#Low water tank threshold. Don't water if below this.
name: Low tank water threshold
icon: mdi:water-remove-outline
optimistic: true
min_value: 0.0
max_value: 20.0
step: 5.0
restore_value: true
initial_value: 10.0
button:
#Deep sleep if "allowed".
name: Sleep If Allowed
internal: ${internal_mode}
icon: "mdi:sleep"
on_press:
then:
- if:
- binary_sensor.is_on: stay_awake_sensor
then:
- logger.log: "Sleep requested but STAY AWAKE mode is on. Skipping sleep."
- deep_sleep.prevent: deep_sleep_1
else:
- logger.log: "Sleep requested and ALLOWED. Going to sleep..."
- deep_sleep.enter:
#Force Deep Sleep
icon: "mdi:bell-sleep"
on_press:
then:
- logger.log: "FORCE SLEEP requested...Going to sleep"
- deep_sleep.enter:
#Long Sleep (part of battery saving mode)
on_press:
then:
- logger.log: "LONG SLEEP requested...Going to sleep"
- deep_sleep.enter:
sleep_duration: ${long_deep_sleep_duration}
#Reset culmulative light sesnor reset
binary_sensor:
#Low tank water alert
name: Tank Level Ok
device_class: moisture
lambda: |-
if (id(water_tank_level).state > id(low_tank_water_threshold).state)
{return true;}
else if (id(water_tank_level).state <= id(low_tank_water_threshold).state)
{return false;}
else
return {};
#Data updates alert. I've had the lux/tof playing up. Seems to be when battery < ~ 40%
icon: mdi:database-alert-outline
device_class: problem
entity_category: diagnostic
#Low Battery alert
name: Battery Level Is Low
lambda: |-
if (id(batt_level).state < id(battery_saving_mode_threshold).state)
{return true;}
else if (id(batt_level).state >= id(battery_saving_mode_threshold).state)
{return false;}
else
return {};
on_press:
then:
- button.press: long_deep_sleep #Long deep sleep if battery low.
#Pump Sensor.
name: Pump is On
icon: mdi:water-pump
device_class: running
lambda: |-
return id(pump).state;
#Data Update Sensors.
#These were useful during dev. Might remove in prod.
#All updated via other sensors.
#Moisture
#Battery Level
name: Battery level updated
#Light
#Water level
name: water level updated
#All
name: Data updates done
icon: mdi:database-refresh-outline
lambda: |-
return
id(solar_plant_moisture_level_recieved).state &&
id(batt_level_recieved).state &&
id(irrigation_lux_recieved).state &&
id(water_tank_level_recieved).state
on_press:
then:
state: OFF
#Log that updates are all done
- logger.log:
format: "All sensors updated after %.1f secs of uptime. Checking if watering is required"
args: [ 'id(uptime_sec).state']
- delay: 100ms
#Water if required and allowed then go to sleep. Note watering will only happen if total system is healthy (by design).
- if:
and:
#Check if our watering regime wants a water dose
- lambda: return (id(watering_mode).state == "Wetting Mode");
- binary_sensor.is_off: battery_level_is_low # Not in battery saving mode.
- binary_sensor.is_on: tank_water_level_is_ok #Tank Water is ok
- binary_sensor.is_on: auto_water_sensor #Auto water is enabled
then:
- logger.log: "Watering required and allowed"
- switch.turn_on: pump
- delay: ${pump_run_time}
- delay: 1s
- button.press: sleep_if_allowed
else:
- logger.log: "Watering not permitted!!.." #todo log reason?
#Deep sleep control
#A lot of my logic is remashes of:
#https://www.wirewd.com/make/blog/esphome_sleep_modes
#https://tatham.blog/2021/02/06/esphome-batteries-deep-sleep-and-over-the-air-updates/
#Import HA Deep sleep control
internal: false #I want to know that everyone is talking to each other;)
entity_id: input_boolean.keep_esps_awake_switch_ha
icon: "mdi:sleep-off"
on_press:
then:
- logger.log: "STAY AWAKE requested from HA. Preventing deep sleep"
on_release:
then:
- logger.log: "STAY AWAKE TURNED OFF. Going to sleep..."
- deep_sleep.enter:
#Import Auto Water control
internal: false
entity_id: input_boolean.auto_water_planty
icon: "mdi:auto-fix"
script:
#Pump auto off timer
- id: run_pump_for_pump_run_time
then:
- logger.log: "Running pump for ${pump_run_time}"
switch:
#Pump
- platform: gpio
pin: ${pump_switch_pin}
internal: false
restore_mode: ALWAYS_OFF
on_turn_on: #Auto off timer. Flood protection.
- script.stop: run_pump_for_pump_run_time # Stop any existing timers.
- script.execute: run_pump_for_pump_run_time # Start new timer
#Control peripheral power (on solar power manager)
- platform: gpio
name: Power Peripherals
pin: ${power_peripheral_pin}
internal: true
restore_mode: ALWAYS_ON #Power on when waking from sleep.
globals:
#For daily battery level change (below). i.e net energy production or loss.
#Globals survive deep sleep
- id: previous_value
type: float
restore_value: yes
initial_value: '0.0'
#Track end of day battery
name: End of Day Battery
update_interval: never
icon: "mdi:solar-power"
accuracy_decimals: 3
on_value:
then:
#Calculate change in end of day battery and publish to sensor
- lambda: id(change_in_end_of_day_battery_percent).publish_state(x - id(previous_value));
#Set previous value as current value.
- lambda: |-
id(previous_value) = x;
#Track daily changes in battery (i.e net solar production)
name: Change in End of Day Battery
icon: mdi:trending-up
internal: false
#Uptime sensor
- platform: uptime
update_interval: 2s
accuracy_decimals: 0
unit_of_measurement: s
#For counting data updates recieved for each wake cycle.
#Manually updated via publishing from other sensors.
#Track Lux updates
name: "Count Lux Updates"
icon: "mdi:counter"
unit_of_measurement: count
#Track ToF updates
name: "Count ToF Updates"
#Track battery updates
name: "Count Batt V Updates"
icon: "mdi:counter"
# Time of Flight sensor - i2c
#Powered via 5v
- platform: vl53l0x
i2c_id: vl53l0x_i2c_bus
# setup_priority: 300
internal: false
address: 0x29
timeout: 300ms
#never
# enable_pin: GPIO17 #Did not work: https://github.com/esphome/issues/issues/3644
accuracy_decimals: 1
unit_of_measurement: 'cm'
filters:
- multiply: 100 #Convert to cm
- median: #Moving median to smooth noise. Sample 5 points then push.
window_size: 5
send_every: 5
send_first_at: 5
on_raw_value:
then: #Push sensor update counter.
- lambda: id(count_irrigation_tof).publish_state(id(count_irrigation_tof).state +1);
#Convert the ToF distance to a water tank level (% full)
- platform: copy
source_id: tof
internal: false
# icon: "mdi:battery"
name: Water Tank Level
entity_category: ''
filters:
# Map from distance to % full. To calibrate.
- calibrate_linear:
- 3 -> 100
- 19.5 -> 0
##Overide values less than 0% and more than 100%. Round to 0.5%.
- lambda: |
if (x > 100) return 100;
else if (x < 0) return 0;
else return ceil(x / 5) * 5;
on_value:
then:
state: ON
# bh1750 Lux/light sensor
- platform: bh1750
i2c_id: bh1750_i2c_bus
# - id: bh1750_i2c_bus
# sda: GPIO25 #data > green wire
# scl: GPIO27 #clock > blue wire
# scan: true
# - id: vl53l0x_i2c_bus
address: 0x23
filters:
- median: #Use moving median to smooth noise. Sample 5 points then send.
window_size: 5
send_every: 5
send_first_at: 5
on_value:
then:
state: ON
on_raw_value:
then:
#Sensor update counter.
- lambda: id(count_irrigation_lux).publish_state(id(count_irrigation_lux).state +1);
#Measure of total light per day. Poor persons DLI https://en.wikipedia.org/wiki/Daily_light_integral
- platform: integration
name: "Light per day"
sensor: irrigation_lux
time_unit: s
unit_of_measurement: lux*s
restore: true
#Notes:
#Voltage divider: Used 2 x 300K Ohm resistors
- platform: adc
internal: true
pin: ${batt_voltage_pin} #ADC1
accuracy_decimals: 2
attenuation: auto
filters:
# #Scale it back up from voltage divided value 2 x 300K > 2.1. 4.2/2.1 = 2.
- multiply: 2
on_raw_value:
then:
- lambda: id(count_batt_voltage).publish_state(id(count_batt_voltage).state +1);
#Intermediate sensor. Might consolidate them later.
- platform: copy
source_id: batt_voltage
icon: "mdi:battery"
internal: false
unit_of_measurement: V
filters:
window_size: 10
send_every: 10
send_first_at: 10
#Convert the Voltage to a battery level (%)
- platform: copy
source_id: batt_voltage_filtered
internal: false
icon: "mdi:battery"
filters:
# Map from voltage to Battery level
- calibrate_linear:
- 3.1 -> 0 #Set 3.0 to 0% even though it can go lower (2.4V), for life extention. There's not much capacity below this anyway.
- 4.1 -> 100 #Set 4.05 to 100% even though it can go higher (~4.2V), for life extention.
- lambda: |
else if (x > 100) return 100;
on_value:
then:
#Publish that data is recieved
state: ON
#Capacitive soil moisture sensor: https://www.aliexpress.com/item/32832538686.html?spm=a2g0o.order_list.0.0.55771802WgNqEA
#Voltage of the Capacitive soil moisture sensor
- platform: adc
name: Soil Moisture Volts
pin: ${soil_moisture_pin}
internal: false
# never
attenuation: auto
filters:
- median: #Use moving median to deal with noise. Sample 10, push 1.
window_size: 10
send_every: 10
send_first_at: 10
#Convert the Voltage to a moisture level (%)
- platform: copy
source_id: soil_moisture_voltage
internal: false
icon: "mdi:water-percent"
filters:
#max and min values taken from testing with glass of water. Prob need to do in-situ tests.
- calibrate_linear:
- 1.66 -> 100.0
- 2.90 -> 0.0
#Handle/cap boundaries
- lambda: |
else return (x);
on_value:
then:
#Data update recieved.
state: ON
#Help manage the watering mode.
#TODO: Monitor/test
- lambda: |-
if (x < id(moisture_lower_threshold).state)
{ return id(watering_mode).publish_state("Wetting Mode");}
else if (x > id(moisture_upper_target).state)
{ return id(watering_mode).publish_state("Drying Mode");}
on_value_range:
- below: !lambda return id(moisture_lower_threshold).state;
then:
- lambda: return id(watering_mode).publish_state("Wetting Mode");
- above: !lambda return id(moisture_upper_target).state;
then:
- lambda: return id(watering_mode).publish_state("Drying Mode");
This post is for content relating to it’s operation.
I’ll start with a high level description. It essentially works very similar to other irrigation and deep sleep projects projects around:
- Wake up from deep sleep periodically and see if the plant needs water. If so, water, if not, back to sleep.
- Don’t water the plant if battery is low, instead, go back to sleep for a long time and hope you get recharged on next wake.
- Don’t water the plant if the tank level is low.
- The watering regime might be described as “incremental drip-feed towards an upper target, followed by drying towards a lower threshold”. This lets the plant dry out a bit, then “gives it a good water, but slowly rather than all at once”… I still need to monitor that this is working ok.
- The light sensor is handy for checking how much light both the plant and the solar panel is getting.
