My solar installer sent me an email today to let me know that I am still using the V1 API to access my solar panel production data and that this service will be discontinued in November.
It is not clear to me if the current integration supports the V2 API, and if it does how do I setup the OAuth? It looks like I have to tell OAuth setup which computer is going to request the authentication.
Here is what they said.
SolarEdge has announced that its current API platform (known as V1) will be retired on November 3, 2026. After that date, applications that rely on the older API connection method will stop working unless they are updated to SolarEdge’s new V2 platform.
What does this mean for you?
If you use a third-party application that connects to your SolarEdge monitoring account, you may need to reconnect that application using SolarEdge’s new authorization process.
The good news is that SolarEdge has designed the new system so homeowners can authorize applications directly. In most cases, you should not need a new API key from ReVision.
What should you do?
Identify any applications, services, dashboards, or automations that currently connect to your SolarEdge system.
Reach out to the provider of that application and ask if they support the SolarEdge V2 API.
Follow any migration or reconnection instructions provided by that application’s developer.
Complete the migration before November 3, 2026 to avoid interruptions in data access.
Where can I learn more?
SolarEdge provides documentation and self-service tools for homeowners who want to access their own data:
- SolarEdge Developer Portal: https://developer.solaredge.com
Homeowner and Self-Access Guide | 1 - Developer Platform Docs
