I’ve been using the SolarEdge integration for a while now, but since the last hassio update (0.102.3), the integration stopped working. Anyoneelse experiencing this issue?
Hi.
You are totally correct. There is a bug in the new version. I have tried changing the API Key with no luck. It does not work anymore.
The integration has been fixed in the 0.103 update.
Updated and still does not work. I have rebooted the server twice.
Same for me, running 103
I went from 102.2 to 103.0 (never tried 102.3). Other than the occasional Update of sensor.solaredge_current_power is taking over 10 seconds
, I’m not seeing any problems on my side.
Same here: 0.103.3
I have managed to overcome this.
Remove the code from the configuration.yaml.
Define it through the UI. I also asked SolarEdge to upgrade my firmware which did not help.
