SolarEdge entities no longer available?
Since I updated to the 2021.11 update, it looks like only the instantaneous and the lifetime entities are still fetched from the SolarEdge website, the values for week/month remain 0.
Anyone else with a SolarEdge integration has noticed this or is it some issue on my side?
Additionally, if a sensor you used disappeared, it might have been disabled by default during upgrade. Please be sure to check if the entity is enabled in that case.
I just enabled them again and most sprang back to life, though a few have changed name so those needed updating also.
same problem here.
integration removed and added again.
keeps having the same problem.
problem solved. after update the sensors were turned off. this turn on and works again
Oh how silly of me, I noticed the disabled icon and even hovered over it and it displayed disabled though I didn’t think of checking whether the entity was indeed disabled in HA rather than disabled as in broken/not available.
I still need to get used to disabled-by-default entities. Strange that I did not see any “breaking changes” listed for SolarEdge on the release notes.
