Could you send me the yaml script for that automation?
I tried to see if i can get it to change once Remote was requested but it doesnt seem to follow this and impliment anything. So i tried a few different methods as you can see but nothing is triggered,
Ive even set the states and still nothing. It doesnt seem to want to impliment the value over to the Solaredge discharge section.
alias: "Solaredge Emhass Discharge "
description: ""
- platform: state
entity_id:
- select.solaredge_i1_storage_default_mode
to: Discharge to Maximize Export
for:
hours: 0
minutes: 0
seconds: 5
- platform: state
entity_id:
- select.solaredge_i1_storage_command_mode
for:
hours: 0
minutes: 0
seconds: 5
- platform: state
entity_id:
- switch.sonnen1_emhass_override
to: "on"
condition: []
- device_id: e7533ab689f119d5f6982876578ab7eb
domain: select
entity_id: df3e28a25183ad78bd53381ee2232533
type: select_option
option: Remote Control
- service: number.set_value
value: "{{states('sensor.solaredge_i1_battery_forcast')|int(0)}}"
entity_id: number.solaredge_i1_storage_discharge_limit
enabled: true
data: {}
entity_id: sensor.solaredge_i1_battery_forcast
mode: single
For anyone also reading throgh this threade. I had to ring solaregde and have them remove Amber (VPP) from the control to resume my control. Now I have full function again
What happens when you manually change the value in that number entity on your dashboard?
Does it change briefly and then return to a fixed value?
Is your SolarEdge inverter enrolled in Amber SmartShift or another VPP/ Grid Services ? If so you may not be able to change those values unless you unenroll. Oh, I see your follow-up so you are unenrolled which is good.
The values i put are working. Ive even setup up a dumb discharge feature through node red and i can input the values using automation, But i cant have that number a variable.
So these flows trigger automations as im working on getting node red smoother using other flows,
But as ive said i can put a variable solution in place for some reason.
Curious if you could try on your system using the site limit as a test as you dont have the same functions as me as your using a tesla. If yours is displaying across could you show me your automation that made that work as ive tried this also.
This error originated from a custom integration.
Logger: custom_components.solaredge_modbus_multi
Source: helpers/update_coordinator.py:322
Integration: SolarEdge Modbus Multi (documentation, issues)
First occurred: 31 October 2023 at 04:23:36 (3 occurrences)
Last logged: 05:00:26
Error fetching SolarEdge Coordinator data: Modbus/TCP connect to 192.168.0.67:1502 failed.
@WillCodeForCats sorry to tag you directly, but this is becomming a bit of an issue for me now and I know itâs a âknownâ issue. Iâm just wondering if you could suggest anything I might be able to do to either diagnose the problem or at least mitigate its impact.
It used to happen once in 24 hours, but now it happens regularly twice a day, usually around 8pm and 5am, but that time can vary by an hour either way. This morning it happened just before a scheduled battery grid charge slot and this happened:
Logger: homeassistant.components.automation.grid_charge_battery_to_full
Source: components/automation/__init__.py:676
Integration: Automation (documentation, issues)
First occurred: 05:00:08 (1 occurrences)
Last logged: 05:00:08
Error while executing automation automation.grid_charge_battery_to_full: Connection to inverter ID 1 failed.
Iâve been keeping a log of every time it happens now.
I canât see anything else in the logs around the same time so I wonder if itâs a polling issue with the inverter?
At the end of the day, I can live with it. I just wondered if there was anything I could do my end to help investigate.
can someone tell me if i can use this integration without having a battery?
basically the installation are just my solaredge panels which sending the produced electricity back to the grid.
Sorry for my ignorance, but I donât have the time to read all 500 posts, and are just wondering if anyone got this working with Fronius Sunspec Modbus?
Iâm looking to replace the Fronius integration with Sunspec instead to get more exact values in the Energy dashboard.
Thereâs really nothing to investigate within the integration as far as connection errors like that go. When you try to send a command it tries to open a Modbus/TCP connection using the pymodbus library and if it canât connect it will return the âconnection failedâ message.
You could go lower level and use wireshark to sniff packets to see whatâs happening on the wire between Home Assistant and the inverter.
There is a difference between reads and writes that I have some retry logic on reads to try and avoid unavailable state, but writes only get one attempt and immediately return error on failure. I could extend retries to writes and see how that goes, my concern that it could cause UI problems in HA with delayed responses if there is ultimately an error. Or maybe it will be fine, i donât know since I can only test writes with my simulator which is more well behaved than the real inverters are.
I also recommend running HA 2023.11.0 or higher or Release v2.4.7-pre.1, either of which will load dependencies for the latest version of pymodbus (3.5.4 as of this writing).
Thatâs a great work, thank you! I have recently installed SE8K-RWB48 with a battery and have a quick question on AC_POWER values.
Does Inverter AC_POWER (40083 40084 1 I_AC_Power int16 Watts AC Power value) ever go into a negative value same as Inverter DC_POWER (40100 40101 1 I_DC_Power int16 Watts DC Power value) does when charging battery from grid and there is 0 PV production?
I have the latest software on the inverter. I had previously a regular SE8K without battery so couldnât observe a negative value due to lack of battery.
